11.1.2 quits nearly everytime i close a session
Title says it all, PT quits nearly everytime i close a session. It happens since version 11.1.
I trashed preferences aso, but it didn't help. Some sessions do not force quit PT after closing them, some do. And some sessions do both, closing normal (keeping PT alive), or force quit PT. Until now i couldn't figure out, what's the reason behind it. It also doesn't matter if i use plugins or not. Yes, i do know that i have an unsupported OS, 10.9.1, but it happend with 10.9.0 also. I don't blame Avid, i just want to know if anyone else has this problem.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: 11.1.2 quits nearly everytime i close a session
Any crash logs? user/your name/library/logs/crash reporter Chris
Haven't looked into it but i sent every single crash report (that one which opens automaticly after a crash) to Avid.
I noticed that the PT Quicktime Helper is quite often unreponsive in the Activity Monitor. Maybe this is it. btw., Avid Video Engine is turned off.
Any other usage patterns that you notice with these different sessions?
For example; If the session isn't doing much and your session drive sleeps, it could be causing the crash when trying to save. Can you open a session you know crashes and close it right after opening. Does it still crash? |
No, it happens when the session is "active". Mostly i close sessions right after editing/mixing it. I rarely let it open without doing something. Quote:
Yes. And it doesn't matter if i save it before closing it or not.
I've had "similar" issues with PT 11 but they all happened after updating other software on my system drive, it seems that some drivers - especially ones that utilise cloud based services - can prevent PT from functioning properly or even booting, have you updated anything recently? I've found that this sort of weirdness is best and fastest solved by simply rolling back to a previous working clone of your system - I keep 2 on hand at all times just in case - I know it's not much help, but it's all I can think of, you might be best to build a fresh system rather than dicking around for ages trying to isolate the problem, also, not sure how your computer is set up, but building a clean minimal system drive with just the stuff you need to do your work - no iPhoto, Office, Photoshop etc - seems to be the best way to ensure smooth sailing (at least in my experience).
Good luck. |
You are not alone. I am also having weird (intermittent) crash problems, it sort of correlates to when I close a session. I am not using any cloud programs. I am using Window 7. Pro tools 11.1.2
I am using (latest version of all 24th Feb 2014): Superior drummer, EZmix, Waves (CLA artist, L3 multimaximizer, Kramner Tape). M-audio ultra 8R. I have un-installed and re-installed all drives and programs. I will brake it again tonight and get an error report. Anyone else having these weird issues?
OS : Windows 7 (SP1) Sequencer :Pro tools 11.0.1 SOUNDCARD: M-audio ultra 8R (main unit), M-audio FW1814, M-audio fast track pro CPU: Intel Quad core Q6600 Motherboard: MSI P45 Zilent Socket 775 Motherboard RAM: Kingston HyperX 8GB (4 x 2048MB) 1066MHz PC2-8500 plugins: Superior drummer, EZmix, Waves (lots) soundcloud.com/peter-thorpe |
Good catch! Same here. PT11 HD doesn't like it when using heavy Track count and the keyboard shortcuts. If we use the dropdown menu to quit and make sure every GUI is closed on plugins we fair pretty well but as soon as we use shortcuts and/or leave any VI open (GUI) PT crashes 4/7 times. Weird but not that hard of a workaround Best Chris
Hi! Thanks for your answer! i tried both ways. And both ways do quit, i can't say which one works better...
Session crash at same point everytime plus BSOD when I force close. Very peculiar! | trevorcwilliams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-12-2012 05:06 PM |
Just reinstalled PT 8 and now for some reason everytime I close and reopen PT.... | Violet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-06-2010 09:51 PM |
PTLE 7.0 Quits on "Close Session" Command | RMW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-23-2006 08:16 PM |
pro tools crashing everytime close session | crizdee | Pro Tools TDM Systems (Mac) | 8 | 10-19-2005 10:28 AM |
computer freezes everytime I close a session??? | dchapp33 | Pro Tools TDM Systems (Mac) | 2 | 03-14-2005 07:02 AM |
