Reference Guide bug
Hi!
Since PT10 i can´t open the PT Refence Guide.pdf (and all other pdf´s as well) from the Help menu in ProTools 11. Will this ever be solved?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Reference Guide bug
I think it will depend on what your system is using as the default PDF reader? It usually defaults to macs preview app. Maybe this is no longer the default reader. Or preview has become corrupt and the system needs to reinstall to repair it. But not sure about this. Chris
No no! ProTools error comes up with:"Pro Tools Reference Guide can't be found" or something...
It doesn't even open!
Is this all PDF overall or do you mean all pro tools PDFs
Chris
Is it possible that you use an other language?
For example I use the script to start Pro Tools in english instead of german. In the english version it work fine. In german I have the same problem. Perhaps there is as yet no german version of the reference guide. |
i mean the PDFs of ProTools cannot be found by ProTools!
Reference Guide | filosofem | General Discussion | 14 | 09-16-2010 11:21 AM |
PT8 Reference Guide? | jeff markham | Pro Tools TDM Systems (Mac) | 8 | 12-18-2008 04:01 PM |
Reference Guide for LE? | Sparks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-29-2004 10:47 AM |
reference guide | shaun1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-04-2004 08:27 AM |
Guide of Reference Where I can get it | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-13-2004 05:55 PM |
