PT11 language
Will v11 have multi-language support with the option, to choose the language? In v10 it's dependent on the system language, but in my case i prefer PT in english on my MacBook with german language, which doesn't work in PT10.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: PT11 language
I'm interested about this as well, so let me throw this question at Avid... :)
Re: PT11 language
Oh yeah, thanks for posting this!
That's definitely a want.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: PT11 language
Why not erase the other languages?
I prefer english too - so here is what you could do: right (or control) click on the ProTools program icon - select show content (oder "Packetinhalt anzeigen" in the german version) - in the folder Contents you´ll find the folder Resources...there you can delete all xx.lproj [where xx stands for the language] - except en.lproj - yes, you guessed it: en. stands for english But - be careful! Most of the files in Resources are needed! Works here on several systems without any problem [maybe you should not delete the language-folders, just copy them to another / new folder... - just to be save...] |
Re: PT11 language
I ended up using a script, which works just fine.
Re: PT11 language
Yes i tried that once, but that doesn't work 100%, f.e. The Beat Detective window and the plugin windows will still have german parts (i'm quite sure i didn't forget to delete a file).
And i would need to delete all of them after every update.
Re: PT11 language
True - but to get sometimes a german word is not as bad as double-clicking a session and start PT in german... i just hate that
And yes - we should be able to select the language i think |
Re: PT11 language
It is if you're using macros like with Quickeys for example. And I do that a lot. Was a nightmare when PT10 first came out.
Re: PT11 language
Another vote for PT to english without using that start-up script.
Also every updater deletes the starup script and/or removes it from the dock and replaces it by the original PT icon. Little but quite regular annoyance. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: PT11 language
Due to the complete rewrite of Pro Tools 11 as a 64-bit application, it is expected that there will be some errors initially.
Therefore, PT 11 will allow you to curse at it in any language you choose. However, to implement this functionality, an optional language pack will be required. The optional language packs can only be purchased with an HDX 1 system for $17,000.00 USD...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Apple Script for language switch (Ger>eng) in PT11 | Franco1967 | Pro Tools 11 | 1 | 04-14-2014 11:18 AM |
PT11 Language Switch - Feature Request | Joe Sciacca | Pro Tools 11 | 6 | 06-27-2013 01:18 PM |
Language | chek0 | Pro Tools Express on Mac OS X | 0 | 12-06-2012 08:55 PM |
How to change the Language of PT 8 | gmorey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-26-2009 11:21 AM |
