Clip Gain and volume autiomation
Is there a way to use the clip gain feature and then go to the volum od the track so you can make the volume go up or down. I have a drum track and use clip gain toget more level, then in a place i need it to really come down so I took the voule level of the track and pulled it down in the section but it still plays even all the way down??
Wow am I groovy or what |
Re: Clip Gain and volume autiomation
why use clip gain if i am going to turn it down you ask. because some of the track is not going to be used. Clip gain compared to gain in audio suite is nicer to work with. Ther was no bleed as the track was solo. Not sure i think when clip gain is engaged it turns off,, auto read.
Any other Motu users out there?
Clip gain or Volume Automation for S's on Vicals | SpinningDisk | Tips & Tricks | 12 | 12-20-2013 06:52 AM |
What's the difference between clip gain and volume automation on audio? | rockguitarist1255 | Pro Tools 10 | 7 | 12-27-2012 07:20 PM |
Bug? Coalescing Clip Gain to Track Volume makes Fades pumping. | jojohamps | Pro Tools 10 | 0 | 04-05-2012 08:15 AM |
Clip-gain post-EQ but pre-volume-graph? | Frank Kruse | Post - Surround - Video | 11 | 11-29-2011 10:18 AM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
