HD 10 error 6031
I've been working with Avid support for a month on this and can't seem to stop this error. Anyone have any ideas?
Re: HD 10 error 6031
Could you give LESS info? What interface, what OS? What hardware? Have you read this: Help us Help You - READ THIS Before Posting!
Do you have Acronis True Image installed? Can you post a Sandra report?
sorry about that:
Windows 7 Pro 64 bit HD 1 Core Card HD I/O Pro Tools HD 10.0.1 No Acronis Here's the Sandra Report: SiSoftware Sandra Computer Model : Gigabyte X58A-UD5 Workgroup : WORKGROUP Host Name : musix User : lenny Processor Model : Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz Speed : 3.24GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte X58A-UD5 BIOS : Award (Phoenix) FB 08/24/2010 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 24GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Total Memory : 24GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 540MHz (1GHz) Memory Module(s) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A2000C9 4GB DIMM DDR3 PC3-16000U DDR3-2000 (7-7-7-20 4-27-8-4) Video System Video Adapter : AMD Radeon HD 6700 Series (800 SM5.0 850MHz, 1GB DDR5 4x1.2GHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : AMD Radeon HD 6700 Series (800SP 10C 850MHz, 1GB 4x1.2GHz) Compute Shader Processor : AMD Radeon HD 6700 Series (800SP 850MHz, 994.4MB 4x1.2GHz) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (C:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (E:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (G:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (F:) ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices System Reserved : 100MB (NTFS) Audio (E:) : 930GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Audio_old (G:) : 930GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Samples (F:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Optical Drive (D:) : N/A @ ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Pine Technology EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte 88SE9128 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Network Adapter : Realtek PCIe GBE Family Controller #2 (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Not sure if it would help you, but you should read this thread, just the first part of page 1.
http://duc.avid.com/showthread.php?t=238426 Specifically, this part W7 users!!!! You may wanna check out this IEEE 1394 Hotfix!!!!! this hotfix addresses issues that some may have with their F/W connections. Please check out the MS disclaimers!!! Also, have you tried moving the core card to another slot? Wonder if you have an IRQ conflict
Looks like the memory settings might be at default. If you haven't done so, I would kick up the mem bus speed to at least 1200 and make sure your memory settings are per the memory spec in the bios (you likely will have to do this manually).
Hope this helps, Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
The only slot I haven't tried for the HD card is the second pciex 8 slot.
Can't get to the first one because the video card covers it up. I've move the video card to the 2nd pciex 16 slot and the HD card in the first but the same crap. Going to take it apart and try the 2nd pcie 8 slot for the HD and leave the video in the first 16. Is it normal when you disable hyperthreading that the OS only see's 4 cpu's instead of 8? I notice Avid does not support hyperthreading. We've moved all 3rd party plugins to an unused folder, no effect reset preferences, no effect |
Avid has supported hyperthreading for some time.
And yes, if you disable hyperthreading, only 4 cores will show up as that's all you have. Cheers,
Where did you see PT doesn't support hyperthreading? It supports it just fine. Its the hyperthreading that makes the program "see" 8 cores instead of 4(so yes, that's normal). I've gone back and forth on my systems and, for the most part, hyperthreading ON yields the best [performance.
I was looking at the BIOS settings that they suggest for the HPZ800 and it said Avid does not support Hyperthreading.
I notice it doesn't respond as well without it so I'm changing it back to Hyperthreading. I also put the memory up to 1600, no effect. Changed the slot for the HD card to the 8x pcie slot no effect. Removed the amd driver for the video card and am using the Windows driver no effect. What's left? MAC time?...11k into this thing so far and nothing but disappointment. |
A strange thing is also happening with my PC. Some times my C drives states it has 22GB free and then other times it says 10GB free. Even though I've not installed to uninstalled anything
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Run out of CPU error 6031 | Roland Clarke | Pro Tools TDM Systems (Win) | 0 | 01-22-2013 08:41 AM |
Error -6031 | fisaac | Pro Tools TDM Systems (Win) | 19 | 04-01-2010 11:54 AM |
error -6031 | cwarrenk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2009 10:39 AM |
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O | booyaaslam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2002 01:55 AM |
DAE error -6031 | binet | Pro Tools TDM Systems (Mac) | 1 | 07-09-2000 06:59 PM |
