Old 04-01-2019, 06:52 PM
Default Re: Lost ilok
Originally Posted by Gentoo View Post
Ok, I have purchased a new iLok. I went through the linking process in my account manager. When I log in, I see the old one there unless the name carries over.
Before I can activate a license and put it on this iLok, it is telling me that I need to surrender a license. Looks like from the original purchase. When I try to do that, it won't let me. And the continue button is grayed out.
Problems are most likely caused by you not following all the (complex) steps correctly, and other folks here cannot guess exactly what you have done.
Did you follow the Process for a lost iLok that was given earlier? What exactly have you done? Did you get responses from your RMA submission to iLok. Was the iLok synchronized or not... aka had you purchased iLok Zero Down Time? If not did you pay to create an Avid support case?
Old 04-01-2019, 10:39 PM
jeffro's Avatar
jeffro jeffro is offline
...Before I can activate a license and put it on this iLok, it is telling me that I need to surrender a license. Looks like from the original purchase. When I try to do that, it won't let me. And the continue button is grayed out.
Pro Tools Perpetual Bundle (with 10/11/12) is the newer license bundle that added support for 12.6/higher and was deposited in your account in Sept 2016. It was never activated so it still needs your previous bundle to upgrade from (which you obviously can't do since the iLok containing that bundle is lost).
Found your support case and will respond to that, so please look for a case notice email...
linkedin
Old 04-01-2019, 11:00 PM
Gentoo Gentoo is offline
Ok, thanks Jeffro
Old 04-01-2019, 11:08 PM
Yes!!!!! I am back in business! Thanks for the help and this iLok is attached to a chain so nothing ever happens to it.
Thanks again!
Old 04-01-2019, 11:19 PM
Thanks again!
Great you got it going. You should consider purchasing ZDT.
Old 12-06-2019, 09:37 AM
johndoc johndoc is offline
I lost my ilok back in 2015 and I submitted an RMA at the time ( I still have this ). I did not require Pro Tools at that time as I had changed careers and was working abroad. I have put together a small home studio for the first time in years and was hoping I could get my old Pro Tools 10 licence back.
I have submitted a case on avid using an old ACS code which seems to have went through. I always had a spare ilok and that is now synched to my ilok account and I am just running on PT first for the time being.
Can anyone confirm how long it will take to receive a response from Avid about this? and if I will even be able to obtain my old licence as the RMA was submitted back in 2015?
Case -03838673
Thanks Guys!
Old 12-06-2019, 09:56 AM
jeffro's Avatar
Originally Posted by johndoc View Post
...I have submitted a case...
Welcome to the community. Will check on this and reply via case.
linkedin
Old 12-06-2019, 10:06 AM
Thank you Jeffro!
Old 12-09-2019, 07:48 AM
Any luck with my case Jeffro?
Old 12-09-2019, 01:24 PM
jeffro's Avatar
Should be able to handle this today. Thanks for your patience!
linkedin
iLok lost... I can't transfer my licence on my new ilok... Sarney Licensing & Accounts 12 07-18-2022 03:37 PM
Lost iLok TaylorH macOS 5 09-28-2012 12:26 AM
HELP!!! I lost my ilok!!! CarlosGrether Pro Tools 10 3 04-20-2012 02:18 PM
Lost thread "Stolen or lost iLok" stargazer Pro Tools TDM Systems (Mac) 0 03-18-2006 03:44 PM
