5 96K sessions snags on launch/corrupted in ACCEL
6.2.2 installed
i just want to alert or say that i have 5 96K songs sessions already to mix in HD alsihad ACCEL with a trueverb waves plug installed and after upgrading to accel all of these session are corupted and will not get past the snag of this one WAVES trueverb plug plug's aux send....the funny thing there are two usages of this plug and that one is ok when i import the session matter into an black new accel 6.2.2 session no problems..when i re-build the omitted one with a fresh aux and plug..it re corrupts the session other 96K sessions on my drives with the same exact preset i built on this computer boot up just fine ....only the 5 tunes by this one band....i'm stumped but i will fix this one way or another the other nite i fixed it thru importation so i could mix a tune and all went well..at nite's end i archived and on a lark tried to launch the session after i had bounced the mix and clients were gone ....now it too is snagged...i have my work cut out for me to day fix it but i will check back to see if any others find this challenging situation familiar
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Re: 5 96K sessions snag on launch/corrupted in ACCEL
can you post findings?
(optimistic) |
tech support of course suggest that i may have a waves issue and to call them
i will and if i find out anything i will post here my findings. i'm still hoping to hear from my duck brethren in here today...so please post
jimmy
a waves tech guy admitted to me today that there is an issue with panther and trueverb
my settings which were created in 5.3.1 ....just one of them was errored and had permeated many of my sessions cuz i use a template session all were 96K but not all of them has the virus..... once again the simptom it hangs on the bad plug on launch in 6.2.2 digi claims not their fault and this time i believe them. anybody else had this happening yet? i had 2 trueverbs in each session and only the one i used for a ittle drum room was errored...it was the first on in the order of line up
one waves tech support guy says trueverb and renverb are not compliant with 96K session
and i should "count my blessings that they worked this long" the other spent a lot of time with me and even called on a few followup calls
Does anybody know why sessions do get corrupted? | DHG MUSIC | Pro Tools TDM Systems (Mac) | 16 | 10-27-2009 10:49 AM |
Now that you're on 8, do u still get corrupted sessions? | PTLExp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-30-2009 07:20 AM |
Corrupted PT sessions...? | Muzoid | Pro Tools TDM Systems (Mac) | 5 | 03-23-2009 09:38 AM |
corrupted sessions? | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-02-2005 07:48 PM |
Why corrupted sessions? | John McDaniel | Pro Tools TDM Systems (Mac) | 11 | 11-02-2002 12:09 AM |
