Rewire & 6.1 NO Reason Channels?
I have just updated to 6.1 and have Reason 2.5 on my Mac. When I select the Reason plugin in the insert on a channel it launches Reason but shows a dialogue " No Reason channels active" - a rewire mixer has been found , but no Reason audio channels are activated. Please activate at least one channel."
So then I go back to the Rewire plugin and select an output next to where it says Reason, then i relaunch Reason again and the same dialogue pops up? I am getting frustrated!!! Can Anyone help??? |
Re: Rewire & 6.1 NO Reason Channels?
check you midi connections in the reason prefs.
how did you have reason connected to your computer before? via usb through a midi hub? you now need to plug into your 002 or 001/mbox or whatever and change the midi prefs in reason to reflect this. after that you should be fine. good luck.
www.djdredd.com |
djdredd: you've used Reason under PTLE 6.1 via ReWire on a Mac?
Quad 2.5 G5, 4.5G RAM |
Rail
everything worked fine.
www.djdredd.com |
Hi
Thanks for your replys. I do launch the Reason plugin from Protools and this is when it gives this message. I think select a channel in the plugin and nothing happens? Cheers Jake |
Jake - so let's break this down...
1. Make sure that Reason is not running. 2. Start Pro Tools 6.1 3. Create a new session 4. Create 1 stereo track 5. Instantiate the Reason plug-in on the stereo track 6. Reason should start on its own 7. In the plug-in after Reason has started, assign the Reason outputs to Mix L+R 8. In Reason create a device and assign it to outputs Mix L+R. If you follow these steps what happens.. In step 6 does Reason start on its own? If this doesn't work.. then reinstall Reason and dont move any Reason files from where the installer placed them (for instance if you wanted to be able to start Reason from the desktop.. make an alias there.. dont drag the actual app to the desktop). Rail
Hi Rail,
I have followed the steps in your list and Reason opens but displays the message as I stated in my originall post and when I click OK it quits? I don't get chance to change things in reason. Cheers Jake |
Hmm.. I'd still try reinstalling Reason.
Rail
Hi Rail,
I have reinstalled Reason and it now works fine. Thanks for your help - sometimes one feels mad when you try to sort things out! Cheers Jake [img]images/icons/smile.gif[/img] |
Reason Rewire | S.TaylorRCC | Pro Tools 10 | 3 | 12-12-2011 08:42 PM |
ReWire dropping channels | scottgreiner | Pro Tools TDM Systems (Mac) | 0 | 12-08-2003 01:58 PM |
Reason? Rewire? | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-11-2003 11:17 AM |
how do you bus 6 channels from reason into PT?? | lukeyy | Pro Tools TDM Systems (Mac) | 2 | 09-30-2003 08:06 AM |
Individual audio channels in, from REASON... ideas? comments? | Madmaxxb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2002 08:40 PM |
