Old 01-11-2007, 12:47 AM
Repooc Tserrof Repooc Tserrof is offline
Default Can\'t add or move Beat Detective Markers?
I am using Pro Tools LE 7.1 on a 002r and can't get consistency out of the Beat Detective Markers. I have went through the whole process of aligning the grid/tempo and generating markers, but I am unable to consistently slide the markers left or right. Also adding a new marker rarely works. Sometimes the markers even dissappear when I click or drag them. I am working on a track that doesn't have very sharp trigger points so I need to do this manually. Any help would be greatly appreciated. Thanks.
Old 12-12-2008, 08:45 AM
mode4music mode4music is offline
Default Re: Can't add or move Beat Detective Markers?
I am having the same problem. I hope someone can answer this...
Old 12-12-2008, 09:06 AM
daeron80 daeron80 is offline
Default Re: Can\'t add or move Beat Detective Markers?
Try using a MIDI track to record a click track. Editing the MIDI notes is easy. Once they're right, create the tempo track with Beat Detective in MIDI mode.
David J. Finnamore
Nyquist was right.
PT 2019.10 Ultimate | Omni | macOS Sierra
PT 2019.10 | Saffire Pro 40 | Win10
Old 12-12-2008, 09:14 AM
Phil Ogden Phil Ogden is offline
1. Are you adjusting the sensitivity slider to optimize the creation of markers?
2. Make sure that the BD resolution (e.g 'contains 1/16th note') is sufficient to permit the markers to be moved. For example, if it's set at 8th's, you won't be able to move the markers onto a 16th.
3. I assume you can move the markers with the shift key held.,right?
http://www.myspace.com/philogg
Aligning Midi to Tempo Map with Beat Detective-Can't move analysis markers. Dizzi45Z Tips & Tricks 7 08-25-2015 03:35 PM
Beat Detective best place for transient markers? Iron Shirt Pro Tools 10 0 05-09-2012 07:39 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 03:14 PM
what do grid lines do after beat detective bar-beat markers cc1 Pro Tools TDM Systems (Mac) 1 05-22-2007 10:34 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 02:31 PM
