Validation loop
Hey everyone,
Has anyone had a problem with an 002 "dis-communicating" with a session ("Pro Tools cannot communicate with the Digi002"), and then entering a validation loop where you get the validation text followed by only one dot (.) and then locking up there? If I give a knock it comes back to life and adds the 2 other dots (. .) and then goes into the session. It happens even when my PC is off, (only without the "Pro Tools cannot communicate with the Digi002" popup box). It'll just start the validation sequence again and again with slight fadar noises and a dead stick. It also does it when running an LED "All On" test. All of the LEDs come on, then all go out (except the mute LED) and then the fadars start clicking, then into the validation loop, loading, fadars clicking, blank screen and the validating all over again. Is this something to do with the Power harness cable??? that I've read about here in the DUC? Anybody know the warranty on something like that? Thanks, Ted PS Of course I tried emailing Digi but their email server's down tonight. System version v 1.07 Sum=CBF5 Firmware Boot version b1.00 Sum=47E6 Firmware Fadar version v1.05a
Drums are just a part of Hell that wouldn't catch on fire; and drummers are the kind of man the Devil wouldn't hire. J.P. Richards (1969) |
Re: Validation loop
Yes, this is a known problem. There is a bad power harness in your 002. Call tech support and they'll send out a new one the next day. It is really easy to install and will fix your problems.
Brian |
Re: Validation loop
Thanks, Brian.
I purchased the unit on 12/19/02. Will they (Digi) give me a hassle about this time frame? Or is this a known defect that they are aware of and should have notified us about? Also, what's the warranty period for the 002? I couldn't find it anywhere. Have they said that it voids the warranty if I should replace the harness? Ted
Re: Validation loop
No, they know all about it. I wish I knew a percentage of the units that were bad. (seems like nearly %50 at times) Its been such a large problem that they prefer you to do the fix yourself and promise you that if you follow their instruction it will remain under warranty. They'll have one at your doorstep tomorrow if you call today.
Cavell Studios |
Validation from Digidesign for Mac OS 10.6.3?? | Digg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-30-2010 03:51 PM |
7.4.2 validation code | frangray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2008 06:52 AM |
PT LE 6.9 Validation | Strizer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2006 01:00 PM |
002 validation seems to fail | mike m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-11-2004 08:05 PM |
Validation has gone away | radioguru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-02-2004 01:58 AM |
