Old 10-24-2013, 12:23 AM
lkmuller lkmuller is offline
Default True-Z settings
The Eleven Rack Manual suggests setting the True-Z input to 1M. It says you can do that manually but for the life of me I can't figure out how to do it. Does anyone know how to do it, or where I can go to get the info? Thanks much, as you can tell I'm a brand new Eleven Rack owner.
Old 10-24-2013, 08:07 AM
nst7 nst7 is offline
Default Re: True-Z settings
Page 20 and 21 go into more detail about how to change the parameters using the knobs, including the True-Z setting (which is contained in the "Input" icon).
Also, if you have access to the GUI window on your computer, you can access it that way as well. But you'll probably want to make sure you know how to do it using the knobs, in case you want to use that in a live/standalone use.
Old 10-24-2013, 12:28 PM
Benoni's Avatar
Benoni Benoni is offline
I pretty much leave True-Z on Auto, works fine for me. You won't notice much difference either way if you are using active pickups.
You can change the true-z in the on-screen editor or from the 11R unit.
Press edit/back
On the first page you see INPUT
Highlight that block and change the true-z setting.
Or do it from the 11R on-screen editor here:
Attachment 929
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-24-2013, 10:15 PM
Thank you!
Pro tools click settings (1/8 notes or 16th note settings )? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-19-2008 09:59 PM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 08:38 PM
True 48-Bit Mix Bus Chris Lambrechts Pro Tools TDM Systems (Mac) 1 04-15-2002 02:55 PM
Is this True?? Sudsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2001 09:49 PM
Is this true? CStern Tips & Tricks 1 10-26-2000 09:49 AM
