Old 10-19-2003, 10:22 AM
syra syra is offline
Default How do I select multiple output paths?
...and can I have an interface output going the same time with an internal bus?
Thanx
Old 10-19-2003, 11:13 AM
kurt's Avatar
kurt kurt is offline
Default Re: How do I select multiple output paths?
1.) Hold Control key while you select second pair of outputs.
Make sure you can see the + sign after reassigning.
2.) Yes.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 10-19-2003, 01:18 PM
Thanx kurt!! My dreams will now come true...
Can't try it till tommorow but I'll report back...
Old 10-19-2003, 04:16 PM
s2n s2n is offline
It also works with MIDI output channel assignments too.
Old 10-20-2003, 12:39 PM
David Schober David Schober is offline
Thanks Kurt,
I've never heard of that being available. Where did you find it? (the manual that I skimmed thru?)
A great feature, and the kind of info it's great to find in a forum like this.
Old 10-21-2003, 12:39 AM
kurt's Avatar
Let one mono aux channel with inserted plug-in compressor ,
(one with minimal latency) be your microphone input.
Route & record it to one audio channel.
Now you can compress/limit your microphone signal pre record.
Assigning multiple Output Paths w3ird Tips & Tricks 11 07-11-2017 09:47 AM
Select Multiple in Bin. Select Multiple In Timeline??? jonathon_l Post - Surround - Video 9 04-30-2012 08:48 AM
Select Multiple in Bin. Select Multiple In Timeline??? jonathon_l macOS 0 04-29-2012 01:39 PM
Multiple Audition Paths? max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2008 03:15 PM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Post - Surround - Video 4 06-11-2007 11:34 AM
