DANTE and HDX card Max I/O
I have tried a number of searches for what I'm looking for, as well as in the MTRX Studio manual, but things are still unclear. Forgive the question, which must be fairly rudimentary if you use this hardware every day. I don't yet own the HW, hence asking here:
If I have one MTRX Studio connected to one HDX card (both DigiLinks), does DANTE I/O connect to Pro Tools via the network connection, or via DigiLink? And if the answer is "via DigiLink", then should I assume that DANTE and analogue channels must share the available 64 channels between them? A common use case would be: 1. 16 channels of mic inputs (analogue INs) 2. 8 channels taken up by monitor outputs (analogue OUTs) Would that leave me 56 channels left for possible DANTE OUTs (as well as 48 DANTE inputs)? Or can DANTE run independently, over the network, unconstrained by DigiLink? Last edited by Picture Start; 04-10-2023 at 04:29 PM. |
Re: DANTE and HDX card Max I/O
64 channels of Dante are separate from Digilink, but you cannot record more than 64 channels into Pro Tools using Digilink with the MTRX Studio.
For instance, you could expand the MTRX Studio with 64 channels of Dante IO but you couldn’t track those 64 channels in addition to the 16 analogue ins at the same time. You are limited to 64 channels. You patch Dante to Digilink in Dadman.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
1 HDX card and a MTRX studio will provide 64 channels of Digilink I/O . If you want to make a bus send in pro tools -for instance- and send that to a Dante device, yes , you should patch a digilink output (source) to a Dante input (destination) in DADman. (and connect that Dante channel in Dante Controller to the receiving device)
If you just want to route your computer audio with DVS or a Dante AVIO usb(c)device right into the MTRX, no, this won't involve a digilink port and can be patched right away in Dante Controller. You can then add your computer audio in DADman to a monitor profile - for instance - Hopes this helps!
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
Thanks to both of you—it makes sense now. If I want to ensure 64 channels of DANTE, plus ADC/DAC use, I need a second HDX card and a second interface.
I think for a simple setup of monitoring a live recording, plus enough channels of DANTE to feed a foldback system, one card, one MTRX Studio should suffice. Thanks again. |
Keep in mind that, when using 1 HDX card as your playback engine, you can have max 64 inputs and max 64 outputs in Pro Tools, because that’s what the digilink I/O on 1 card provides. In DADman you could feed all 64 digilink outputs to 64 Dante channels if you would like/need to
The needs are: • 32 analogue inputs (for some mic lines, and extra for HW inserts, talkback) • 32 analogue outputs (surround monitoring + HW inserts/occasional summing mixer use) • Some DANTE for feeding headphone mixers. I figure 16-32 channels max. • Somewhere in there, Mac sound routed to a fader in Pro Tools The thought at the moment is for two MTRX Studios—this way all I/O is addressed by DADman, converter quality is the same, delays, unit redundancy, etc. I could just squeak by with one HDX card (16 AD + 16 DANTE-per-MTRX Studio, per card port), but it might be better to add a second card and dedicate MTRX Studio #2 to DANTE concerns for recording, and then switch to analogue when needed. If I ever need more than 32ch of DANTE (get into ATMOS, etc), I'll be happy to have the second card, plus more DSP. Last edited by Picture Start; 04-10-2023 at 06:09 PM. |
Unless you are planning on leveraging the additional mic preamps, additional Dante & ADAT I/O, etc of a second MTRX Studio, it seems like it would be pretty gratuitous. You do technically have enough available I/O within a single HDX card and single MTRX Studio to do what you need to do.
For stuff like routing Mac sound, you have a bunch of options that aren't dependent on digilink at all. Aux I/O for example will route sounds straight from MacOS or specific apps to faders in Pro Tools digitally. You can also route them via DVS/Dante straight into your MTRX Studio monitor profile, making them selectable as a monitoring source. No additional digilink I/O required. If you do go with a second HDX card, perhaps consider just springing for an Avid HD I/O with 16 analogue in and 16 analogue out. They sound great, and would also be better suited to handle the 16 channels of hardware inserts as they automatically compensate for the insert delay. The DAD/MTRX interfaces don't. You need to configure the delay compensation manually. There are plenty of other third party digilink interfaces that spoof the HD I/O to make hardware inserts more seamless. Lynx Aurora, Aurora(n), Apogee Symphony, etc.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
A second MTRX Studio is 5 grand, has a bunch of I/O that I might not really need. But if one dies, I can easily switch to the redundant one for 95% of my work, which can be done with one, with very little disruption. I totally take your point, however. Quote:
A now-discontinued HD I/O would be supported for five years, which should be fine. Last edited by Picture Start; 04-10-2023 at 07:33 PM. |
I'm less inclined to go in the Focusrite/RME-kind of direction. At that point, I think a 16x16 HD I/O would suit me fine for all the reasons you mention. |
I believe that if you use a second MTRX Studio connected to a second HDX card you cannot integrate both properly in DADMAN from a monitoring perspective in the way you can with the full MTRX and second Digilink/HDX cards.
FS: Dante VIA and Dante Virtual Sound Card | henningaround | Buy & Sell | 0 | 12-29-2021 02:04 AM |
MTRX Dante 128 Card Error | MarkH | Pro Tools | MTRX & MTRX Studio | 10 | 08-20-2021 05:42 AM |
WTB Dante card for Behringer x-32 | dwx1958 | Buy & Sell | 1 | 01-08-2021 02:17 PM |
Can't get MTRX Dante card to work... | SomeOtherGuy | Pro Tools | MTRX & MTRX Studio | 25 | 01-22-2020 10:53 PM |
S3 and Dante Virtual Sound card? | Tim R. | Avid S1, S3, Dock and Control App | 2 | 12-11-2017 05:05 PM |
