Re: Best hard drive for recording to?
OK...what about an external drive to use with a Laptop? I need a new, larger one. Any suggestions?
recording on an external drive is usually not recommended. Even less for a USB drive.
So if you have a firewwire port on your laptop I'd go with this G-Technology G-DRIVE 1TB 3.5IN External Hard Drive USB 2.0 eSATA Firewire 800 Or Western Digital Mybook Studio Edition II 2TB 2000GB Firewire 400/800 eSATA USB2.0 The WD is more expensive has double the capacity. Although you'd have to find a way to disable the raid 0 if possible. There's also LaCie D2 Quadra Interface V2.1 1TB 7200RPM External Hard Drive USB 2.0 Firewire 400/800 eSATA with Lacie going over 1 tb will get your external drives that are in fact multiple HD in a raid config. |
External drives are fine, eSATA would be best if you can get an eSATA ExpressCard for your laptop. While Avid did, and still does recommend firewire drives with the appropriate chipsets for the controller and enclosure, they only recommend them for 8x and below for Windows XP and Vista. Starting with Pro Tools 8.0.4 and 9, but only for Windows 7, Avid is recommending USB externals.
The consensus pick for hard drives on the forum right now are 7,200 RPM Western Digital Caviar BLACK drives with a 64 mb cache. One of these in an approved enclosure should be fine. The first question though, especially if it's a Windows laptop, is whether or not said laptop is compatible with Pro Tools. Cheers,
Nick EDIT: I noticed everything i said, was said above me. My bad
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
More coffee, Nick.
Cheers,
#16
What about the WD caviar green much different from the black coz they are about half the cost of the black
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#17
NOT GREEN. They have a power saving feature, which you don't want to have happen when recording.
Cheers,
#18
I've just had the worst weekend happen pc failed to boot some windows error, then rom drive would read DVDs etc etc
Ok getting to point I think my raptor has just died, took my pc to the guy who built it for me and we are looking at a new drive. I no nothing about technical side but he's quite clued up. So we start looking at hard drives and they are doing a special on the WD green 1 TB the weed has said you don't to use these so I told my friend. He then got up the spec sheet of the green and the drive I'm using at the mo (WD caviar 150 gig quite old) and the green shows a mega improvement the only thing is is that it's 5400 rpm not 7200 rpm and the weed said that it has some power issue thing. Which I told my friend and he said all hard drives turn off when not being used it's a windows thing which u can change. Then he started talking about platters of hard drives etc and it totally lost me. He also explained to me that WD drives are caviar black when they come out then they bring out a new modal which becomes black so the old black becomes the blue Could any chime in on this I'm so confussed why does it have to be 7200rpm when the green which is 5400 rpm would kick my old 7200 drive in the butt
Raoul Crane
#19
I don't know what metrics you are judging "performance" by but 5400 rpm is 5400 rpm and nothing will reduce the write latency time to approach that of a 7200 rpm drive.
You do not want a WD green drive for reasons others have mentioned. If you have friends/"experts" telling you otherwise you need to ignore that advice. You can search here for past explanations. But it's not interesting to drag this up again--from the point the green drive is just not recommended and for good reason. If you want to get stuff done reliably go buy a black. Darryl |
#20
A WD Caviar BLACK 64 mb cache 7,200 RPM drive to be precise.
If your "expert" doesn't agree, get a new "expert". Cheers,
Recording to exteral hard drive | robbie123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-05-2012 07:42 PM |
Should I be looking at recording to an external hard drive? | Judicious | macOS | 24 | 06-07-2011 07:00 AM |
Recording Hard Drive | Davidwilson | Pro Tools TDM Systems (Mac) | 9 | 12-12-2010 12:52 AM |
Is this a good hard drive for recording on Mac? | bruce_pianoman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-25-2005 01:48 PM |
Best recording hard drive for 5.2 LE 0s 9.1 | FLENSER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2004 05:18 PM |
