Pro tools 9093 Hardware buffer size to low problem
Hi
I am using a mbox 2 mini (the usb 1.1 version), and a i5 daw. But can't get bellow 128ms or i get the dreaded 9093 error (Hardware buffer size to low). My os is 32bit Vista I have 2 hdds, one for audio, and they are set in ahci mode (there is IDE,Raid or Ahci) Sisoft system info: SiSoftware Sandra Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : Borealis-PC User : Borealis Processor Model : Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Type : Quad-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P8H67-M LE BIOS : AMI (OEM) 0603 02/11/2011 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2.86GB DIMM DDR3 Chipset Model : ASUS Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 4GB DIMM DDR3 Shared Memory : 130MB Channels : 1 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Kingston 9905471-006A01LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : Intel(R) HD Graphics Family (6 SM4.1 850MHz, 128MB DDR3 1.33GHz 64-bit, Integrated Graphics) Graphics Processor Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz, 128MB DDR3 1.33GHz 64-bit, Integrated Graphics) Storage Devices SAMSUNG HD322GJ (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (C:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) Seagate Desktop 500.1GB (USB) : 466GB (E:) (F:) Logical Storage Devices System Disk (C:) : 298GB (NTFS) @ SAMSUNG HD322GJ (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) Audio Disk (D:) : 932GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) EXT_FAT32 (E:) : 126GB (FAT32) @ Seagate Desktop 500.1GB (USB) EXT_NTFS (F:) : 340GB (NTFS) @ Seagate Desktop 500.1GB (USB) Peripherals LPC Hub Controller 1 : ASUS Cougar Point LPC Controller LPC Legacy Controller 1 : T2 87-71 Audio Device : ASUS Cougar Point High Definition Audio Controller Disk Controller : ASUS Cougar Point 6 port SATA AHCI Controller USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASUS uPD720200 USB 3.0 Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 1.0 |
Re: Pro tools 9093 Hardware buffer size to low problem
What version of Pro Tools? This may be a problem:
EXT_FAT32 (E:) : 126GB (FAT32) @ Seagate Desktop 500.1GB (USB) I'm also not sure about integrated graphics(which traditionally has been a show stopper). The new i5 and socket 1156 motherboards may be different now.
btw. the graphics is that wich is intergrated into the i5 cpu. but it shares memory with my system memory |
btw! worth mentioning, when i first started up pro tools I had the mbox connected to a usb 2.0 port, and pro tools where very unstable and i couldnt get bellow 256ms. So i changed it to the usb 3.0 port. but now it's 128ms
I have an 10 years old PCI graphic card, anyone know if it would be possible to insert that just to see if its the internal graphic card causing the problem? will such an old card even run vista? it propably dont got more than 8mb
I run a $37 MSI GeForce 7300LE 256 card(PCIe) on my rig and its fine(get the latest drive from nVidia.com).
Sandra only shows 1 4gb stick of triple channel RAM. Not sure how that can be running at triple channel speed with only one stick. Probably not the reason your buffer is only getting down to 128, but something you may want to address.
Then again, looking at the specs for the Mbox Mini, 3rd gen, you can only get down as far as 128 samples on Windows. Cheers,
[Edit] just checked out the newest mbox mini, and they still use usb 1.1 on that... that's weird when usb 2.0 is old tech. and now usb 3.0 wich is 10x faster than 2.0 is starting to become the standard |
Pro Tools does not work with FAT-32-formatted drives. They ALL need to be NTFS.
Classic Hardware buffer size problem / error no 6088 | ovi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-05-2008 07:18 PM |
Still getting error 9093: "increase HW buffer size" | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-16-2007 03:02 PM |
h/w buffer size conundrum (9093) (9129) | FatJon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-03-2007 01:09 PM |
Hardware Buffer size problem! | Silvermodak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-09-2006 11:36 AM |
noise+hardware buffer size, and cpu usage problem! | kanxan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-16-2005 04:18 PM |
