"Select All Following" shortcut?!
Hello there, fellow PT users!
I recently switched from Logic Pro, and just haven't figured out the equivalents of Logic's "Select all Following on track" and "Select all Following on all tracks" commands. Similar Nuendo command is 'Select all after the cursor". What's the story in PT? It is a hell of a useful edit function, so it's goota be there, I just don't seem to find it. Thanks |
Re: "Select All Following" shortcut?!
Shift Option Return to select everything after the cursor, and simply Shift Return to select everything before the cursor.
JC Richardson C.A.S. Magick Lantern Atlanta |
Difference between "Go to Song Start" and "Return to start of session" shortcut | pericoloso | Pro Tools 10 | 2 | 09-22-2013 12:44 AM |
unable to select "find all candidates" in relinking window... | duckandcover | Post - Surround - Video | 3 | 09-14-2012 01:19 PM |
Could be finger trouble, but I cannot "Select" - fixed | StefB | ICON & C|24 | 1 | 05-29-2012 01:13 PM |
Strike "not enough physical memory, select smaller size" error | bobbyskeg | Virtual Instruments | 7 | 11-14-2010 05:00 PM |
editpack track select gives "No Valid Tracks"??? | jmattchan | ProControl, Control|24, Command|8 | 1 | 05-27-2009 05:44 AM |
