#4051
Re: i7 Builds - Specs and Results
Sorry. I should have mentioned that the ssd drive was intended for sample streaming in conjunction with VePro. Do you still feel its not worth it? Is there a better alternative? Oh and do you have any specific video card suggestions/recommendations? Thanks.
PRO TOOLS 9.0.2 | MBOX 2 Mini | Intel i7 950 | Win 7 Ultimate BAE 1272 | Whisper Room | R ø d e N T K | Roland JD-800 Vienna Ensemble Pro | Eleven LE | Metal Amp Room Hybrid | Prominy S C | Steven Slate Drums Platinum | Strike Structure LE | sE Reflection Filter | Peavey ReValver MK III |
#4053
I do everything ITB and mainly work with lot's of VI's and samples. I plan on using Win 7 64Bit and get VE Pro to get around the RAM limitation of PT.
With that in mind, here is the system I've decided on (any comments/suggestions welcome): Processor: Intel i7 950 Motherboard: GIGABYTE GA-X58A-UD3R RAM: G.Skill Ripjaw Series 24GB (6x4GB) 240 pin DDR3 1600 System Drive: Intel X25-M SSD 120GB Audio Drive: Western Digital Caviar Black WD1001FALS 1TB 7200 RPM Samples Drive: Intel X25-M SSD 120GB PSU: OCZ ModXStream Pro OCZ700MXSP 700W Video Card: Palit NE2T2200FHD51 GeForce GT 220 512MB 128-bit DDR2 PCI Express. (NVIDIA Chipset) DVD Writer: LITE-ON DVD Writer - Bulk - Black SATA Case: Antec Twelve Hundred V3 Black Steel ATX Full Tower Total including tax and shipping: $1922.69
#4054
Did we ever get any results from Shane's trailblazing build?
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024 |
#4055
Hi Remis, I just have a question about your build.
Have you removed the heatspreaders from your ram because of the noctua? If so, is it an easy operation and did you noticed some decrease in your ram performance or heat/temp? Thanks in advance -Bone |
#4056
Yep, I removed the heatspreaders from 4 of my sticks of RAM. It's easy enough to do, you just use an allen key to remove a few screws in the heatspreader and off she comes. I haven't noticed any issues with it. I actually asked Corsair support about it before buying the RAM and they said it would be all good, with regards to heat and performance. Plus, there's a giant fan drawing air over the top of them anyway.
#4057
Sounds logical, I think i'll do the same then. Thank you:)
#4058
Any other SandyBridge users care to share their findings?
I've been working with a DP67BG and i'm trying to achieve consistency within the results. As mano was saying the clocking works differently and there doesnt seem to be any way to lock the CPU speed on this board, although i've heard that you can on other boards. Either way i'm not sure it matters. It seems to me that the EIST function is actually working well enough for real-time audio without all the fluttering we used to get as the CPU changed state. So far what seems to work best in terms of plug-in count (i'm testing with Cubase at the moment as i dont have any Digi hardware, but i'll get onto PT9 as soon as i can): EIST - on CState - Off CPU - voltage 130w Power - Static (vdroop low (performance)) TDC Current - 100 Turbo on Boost on Internal PLL - disabled Memory 1600MHz XMP 1.65volts All cores set to 45 At low latency it get to about 40% and it starts to crackle - results are still good but i expected to be using more of the CPU. At mid latencies (10ms) it does use the whole CPU and gives brilliant results. It's a bit weird anyway. Any comparisons would be helpful. Cheers Robin |
#4059
Hey robin,
That seems close to what I was seeing, only I got to 60-70% at 64 sample buffer (its the lowest PTLE can go) before it started to stutter. However I didn't see any drop in freq. over time when using static voltage. I have done some fine tuning to BIOS settings over the past weeks and I'm now at 42*100. Having C state disabled means there is no higher turbo mode (single or dual core) only the 4 core turbo number matters. That number is the max freq and (as you've seen) with this board it seems can not be locked as constant. I will post all my current BIOS settings as soon as I get in the studio. in the mean time here is some stuff to keep you posting (if you don't mind ) What memory are you using? (Mine is G-skill and running @ 1.5v) What CPU model# (2600K?) and what Cooler + what temps are you seeing? What sound card/interface are you using? For comparison can you test Cubase CPU % at 64 samples buffer? (seems like 40% was at 32?)
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#4060
Cool,
Memory - Corsair XMS 1600MHz running at XMP profile 1.65V 2600K on the CPU Focusrite Saffire via the onboard FW. Tried a TI FW PCI card and the results were just slightly worse - onboard seems best. I've built up a performance test over the years that runs at 96kHz. For the Saffire this means it can only use down to 128 samples, for a 3.6ms output latency - so that's my minimum at the moment. My results are matching a previously tested Core i7 965 so that's good but it's not very consistent - never seem to get exactly the same result twice :) Edit - cooling, using the Corsair H50 water block, CPU never gets above 60 C. Also 650W HX Corsair PSU. Last edited by Robinv; 02-19-2011 at 03:00 PM. Reason: Added info |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
