#3451
Re: i7 Builds - Specs and Results
Last edited by yamlan; 08-18-2010 at 05:17 AM. Reason: **BUMP** Got it updated... |
#3452
I found the buzz. It is coming from the PSU!!! TR2 RX 750
Separated that puppy from the case and it's buzzing all by itself. This explains why the session ran fine @ 64 with the buzz. The mobo is fine Could it be a bad part that a simple exchange would solve, or are their any other better choices for a PSU for i7?
#3453
Like I said about 1000 times before this company should be called TremalFAKE. If you can replace it with a Seasonic, Enermax, or some other top quality brand.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#3454
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply http://www.newegg.com/Product/Produc...82E16817139006 Big fan very quite.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#3455
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#3456
Yeah that corsair unit is good. Even a 650W would be more than enough.
#3457
I've been following the AHCI discussion here and I think I have it installed correctly in Windows 7/64 but was hoping someone could clarify the steps:
1.I ran the setup off the Gigabyte CD in the GSATA folder - I'm assuming that's what loads the correct drivers for AHCI? 2.Rebooted Windows and GIGABYTE GBB36X Controller now appears in Device Manager under Storage Controllers 3.Entered BIOS and chose AHCI on the Integrated Peripherals screen under "ICH SATA Control Mode" and "Onboard SATA/IDE Ctrl Mode" 4.Booted into Windows and new hardware was detected for all the hard drives and CD/DVD drives Is that all there is to it? Am I running with AHCI now? Also, I read in a thread here that the Intel Matrix Storage Manager was also required - should I install it? Thanks in advance! SiSoftware Sandra Computer Model : Gigabyte EX58-UD3R Workgroup : SANDERS Host Name : EastsideProject User : Chris Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 3.6GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD3R BIOS : Award (Phoenix) FI 03/11/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 3.6GHz (7.2GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 3.6GHz (7.2GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 800MHz (1.6GHz) Memory Module(s) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI Radeon HD 4650 (320 SM4.1 600MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4650 (320 SM4.1 600MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4650 (320SP 600MHz) Storage Devices Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB (E:) Seagate ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) : 466GB (C:) (F:) Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (D:) HP Photosmart C4600 (USB) : N/A (I:) PIONEER DVD-RW DVR-116D (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:) (I:) PIONEER DVD-RW DVR-116D (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:) Logical Storage Devices Backup (E:) : 1TB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) Hard Disk (C:) : 233GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) Hard Disk (F:) : 233GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) Sessions (D:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) Removable Drive (I:) : N/A @ HP Photosmart C4600 (USB) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : Hightech Information System RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) AA01h Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Photosmart C4600 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : () Network Services Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.9
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#3458
#3459
Good deal.
#3460
if you go into device mgr and check the ATA controller setting and it shows SATA AHCI then you are all set
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
