Old 06-05-2007, 10:52 AM
Berrado Berrado is offline
Default Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1
I am setting up an used Pro Tools system which consists of:
- Power Mac g4
- 888-24 I/O
- USD
- Pro Tools 6.4.1 software
However, I cannot get the option of creating tracks or I/O paths in formats other than mono or stereo, and we're setting up a 5.1 room. I was told that 5.1 tracks were available since Pro Tools software version 5, so what am I doing wrong?
Thanks,
Bernardo
Bernardo Pacheco
Old 06-05-2007, 11:22 AM
M Baginski M Baginski is offline
Default Re: Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1
Put Surround Mixer plugin in your plugins folder and move Stereo Mixer to unused plugins folder. Should help.
Old 06-05-2007, 11:23 AM
Wellnitz Wellnitz is offline
Hi Berrado,
look into your Plug-In folder on your harddrive. Is there a surround mixer plug in installed?
If not look on your install cd. you can drag the surround mixer plug in from your cd into the harddrive folder.
Good luck.
Jochen
Old 06-05-2007, 02:11 PM
Ok, so I did this, and when I try to start Pro Tools I get the message:
"Pro Tools with TDM requires the TDM Mixer Plug-In in the Plug-Ins Folder"
And Pro Tools fails to start.
I can´t seem to find this plugin anywhere, is my problem really that one?
Once again, now I have the Surround Mixer plug-in in my Plug-Ins folder, and the Stereo Mixer in my Unused Plug Ins folder.
btw, thanks, guys
Bernardo Pacheco
Old 06-05-2007, 05:22 PM
kurt's Avatar
kurt kurt is offline
Confirm again that Mixer Plug-In is in the Plug-Ins Folder.
Trash Digi Setup & DAE preferences, than restart.
Let us know..
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 06-05-2007, 06:24 PM
Shawn Simpson Shawn Simpson is offline
You need to leave the stereo mixer in the plug-ins folder along with the surround mixer.
Old 06-06-2007, 05:40 AM
That's how I first did it, but it still gave me only Mono and Stereo as options, surround did not show up.
The surround mixer plug in is definitely in the folder, though. I'll try thrashing the preferences and Digi Setup, even though I have re-installed Pro Tools in this computer about three times now, to no results.
Bernardo Pacheco
Old 06-06-2007, 06:50 AM
OK, tried thrashing Digi Setup and Pro Tools Preferences, still got no Surround. What can I be missing here?
Bernardo Pacheco
Old 06-06-2007, 09:10 AM
audiogeek1 audiogeek1 is offline
Have you gone to your I/O set up and created a 5.1 path? Otherwise the default of PT is mono and stereo. The rest you have to define what you want it to be.
Mike
Old 06-06-2007, 10:16 AM
Yes, everytime I did any of the changes suggested here I tried it, and when I created a new path my options were only Mono or Stereo, even If I deleted all I/O (including busses) and tried to start from scratch.
Bernardo Pacheco
Assigning multiple Output Paths w3ird Tips & Tricks 11 07-11-2017 09:47 AM
clear inactive paths from channel output dropdown?? tioshi macOS 2 01-04-2016 07:48 AM
Inserts unavailable: output paths already in use Jack Ruston UK Pro Tools TDM Systems (Mac) 0 12-15-2010 02:50 PM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Post - Surround - Video 4 06-11-2007 11:34 AM
How do I select multiple output paths? syra Pro Tools TDM Systems (Mac) 5 10-21-2003 12:39 AM
