Old 11-11-2005, 11:03 AM
rj333 rj333 is offline
Default Importing Loop Into Session
Please pardon me for this lack of knowledge but I want to learn. What is the best way of importing audio loops into a session. I have some music that I have made and wanted to import some drum loops that I have but the tempo is killing me. Is there somewhere I could get some reading about this?
Thanks,
Rey
Old 11-11-2005, 11:15 AM
liberccxx liberccxx is offline
Default Re: Importing Loop Into Session
there are several ways to accomplish this. if the loops are not "standardized" (such as rex or acid files) then you may want to use a 3rd party. acid pro by sony will handle this effortlessly and will adjust tempo to host tempo. there are others out there but in my opinion none of them compare to acid for use with PT. i think there is an acid demo you could try. if you do, load acid on an aux input track and route the output to an audio track. within acid you play the loop, when it's right, record enable the audio track in PT and away you go. really pretty simple. others may suggest other ways, and i'm sure there are many, but for me, i use this method daily and it works very well.
Old 11-15-2005, 09:34 AM
Thanks very much. That was the best advice ever you had given me. This was so easy and I have had so much trouble fixing this in Protools.
Once again thank you.
Reynold
Old 11-15-2005, 10:04 AM
yavuzj yavuzj is offline
What about TCE plugin?
If your loop is looping correctly, just drag the end to snap to the BAR line in Grid mode and you should be set.
Everything else mentioned is too complicated to do compared to TCE tool.
Unless, you know that you will be changing the tempo again and again....
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 11-15-2005, 11:26 AM
Shan's Avatar
Shan Shan is offline
Why not just use some of the amazing loop tools we have in PT that are free? Beat Detective is amazing for loops. The above mentioned TCE built into the Trim tool is useful at times. We now have Region groups with its own file extension that puts REX files to shame. This has to be one of the best of the new features we have.
Slicing alone can be done in many ways like using Beat Detective or "Separate Regions At Transients" command.
As mentioned there are many ways to do this.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Importing Loop plugins? zhigo16 Pro Tools SE and Essential (Win) 2 01-03-2014 01:34 PM
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 08:35 PM
vst wrapper , importing and using a wav drum loop cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-26-2006 02:25 PM
Importing a loop and inserting it in time Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-27-2001 06:09 AM
