Old 02-05-2020, 01:52 PM
EarHole EarHole is offline
Default HELP: AAF Import Error
Could not complete your request because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/FF/Audio/FF_AudioFile.cpp", line 1045.
(Use the Copy button to copy this message to the clipboard.).
System, Mac PT HD Native on OS10.10.5 / PT 12.4
System had been rock solid and I load files multiple timers a day but today I'm stuck.
I've trashed Prefs, tried three different computers, including a Windows Machine and these files will not load. I've tried track by track but nothing seems to be working.
Old 02-05-2020, 02:03 PM
smurfyou smurfyou is offline
Default Re: HELP: AAF Import Error
Did it come from Premiere? I've seen funky things on the timeline cause this. Or files with illegal characters. Embedded or referenced?
~Will
Old 02-05-2020, 02:11 PM
Came from AVID, which apparently can no longer export OMFs.
Old 02-06-2020, 11:17 AM
Editor exported non embedded versions and they all loaded in fine.
Old 02-06-2020, 11:57 AM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Good to know you have it working.
From Avid MC AAF exports are almost always more robust than OMF's. The Editor can (IMO should) check the AAF Edit Protocol option and PT 10/12 compatible option (I have not needed to try the PT 10/12 option) with AAF exports to Pro Tools.
Andrew
Old 02-06-2020, 08:58 PM
Agree that AAF is a better option. Less quirky for sure. I've just never had a panic attack like this before.
Old 02-06-2020, 11:16 PM
I wonder if the sequence had some odd source file that was throwing it off.
~Will
HTML code is On
AAF import error in PT 11.3.1 dj_tms Pro Tools 11 18 03-25-2017 12:45 PM
OMF Import Error.. Need help! Kaotic macOS 2 08-13-2013 07:49 PM
AAF Import Error bradperry macOS 0 04-15-2011 06:10 AM
OMF Import error Assertion Error 4044 DUCHUNTER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-08-2005 12:45 AM
OMF Import Error ksrmedia Pro Tools TDM Systems (Mac) 1 12-02-2004 02:38 PM
