How to configure HD io in Windows
How does this work in Windows 10?
Mac has the Core Audio App, which doesn't produce sound but at least let's you configure the inputs of the HD io, Anyone?
Within the pro tools hardware configuration settings. I am not aware if Windows 10 has a core audio feature.
Sent from my iPhone using Tapatalk |
Re: How to configure HD io in Windows
Wow ok, so only via the PT app itself?
With a cable coming out of my computer to the patchbay. It's normalled into my monitor controller aux or can patch it into my HD I/O if needed. Makes the core audio whining seem silly don't it . Configuring is done in PT's hardware section.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Yeah that's what I was trying to setup, but I wanted to change the Encl to Optical Spdif which is what's on my mobo....and I didn't know I had to start PT to get to those settings....
I assumed that there was a stand alone app, to set that up....but I guess not. Also I have heard that I need to disable my interface from being the default sound playback device (in the win OS).....is this still true in win10?
Kristof Szobacsi
Hello you guys!! I have a problem with the sync device of avid and the Digidesign 192, technically when you plug in the the serial host of the SYNC device to the PRO TOOLS CORE CARD(in computer) and loop source of the sync to the digidesign 192 when opening pro tools in the session setup clock source should appear….or in SETUP-PERIPHERALS-SYNCHRONIZATION window you could adjust the setting and device or PORT….but it doesnt even appear there…its like the computer cant see the sync device and i cant put it so its the master clock….please help me |
Oh and there is no standalone app to configure because there's no point, the hardware doesn't work for anything but Pro Tools.
Pro Tools 2019.5 Ultimate Windows 10 Pro Join the Facebook Pro Tools Windows User Group |
Thanks Neil
Can't configure XP Pro SP3 and Digi 001 | pouic pouic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-26-2012 05:43 AM |
Please Help me Configure a new Mac Pro for PT LE 8! | raydsr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-06-2009 12:15 PM |
Help me configure my pc!? Please:-) | reiterw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-30-2007 04:35 PM |
What's the best way to configure my system? | Kuleone | Pro Tools TDM Systems (Mac) | 1 | 08-13-2005 12:21 AM |
How would YOU configure your new g4 for OO1 use? | MidiMidiBangBang | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2001 01:43 AM |
