RCA to 1/4 inch cable from dj mixer = no signal
Hello. I am new to the forum and new to audio recording and ProTools.
I am a vinyl dj and want to record a live dj mix. My dj mixer has RCA output only. I purchased a RCA-to-1/4-inch cable, but when I plug the 1/4 inch end into the TRS inputs on my MBox, i get no input signal. I have a diffferent mixer, which I do not prefer to use, which has 1/4-inch outputs. With this mixer, I simply use 2 balanced TRS cables (L and R) and run them from the dj mixer to the MBox, and I get a signal. I would like to use the first mixer with the RCA outputs if possible. What am I doing wrong? Is it that the RCA-to-1/4-inch cable I am using is not balanced TRS? Do I have to buy RCA-to-balanced-TRS adaptors? I am not sure I quite understand the difference between 1/4-inch and 1/4-inch TRS. Maybe this is part of the problem. Any assistance would be greatly appreciated! |
Re: RCA to 1/4 inch cable from dj mixer = no signal
what input setting did you have the MBox set to?
you are going to need Line or DI and I'm going to guess that it was in the default Mic setting. what you want to do should work fine but you may also have bad cables
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Are mixer inserts used sequentially in a signal chain? | illution1 | Pro Tools 10 | 1 | 01-28-2014 01:58 PM |
Splitting Gtr signal with Mackie 1604 mixer | Ping Pong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-02-2007 07:04 AM |
INPUT SIGNAL BOOST ON 002 MIXER? | DEEZGUYZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-08-2006 09:55 PM |
Can Audio Signal Go Through Midi Cable | flymax | MIDI | 7 | 03-02-2001 02:14 PM |
strange signal on mixer channel (in Protools) | E-an | Pro Tools TDM Systems (Mac) | 3 | 07-03-2000 03:30 PM |
