INPUT SIGNAL BOOST ON 002 MIXER?
Does anyone know how to boost the signal on the 002 inputs? besides, the 4/10 switch on the back...remember on the 001 there was a little mixer somewhere in the set-ups menu? I cant find anything like that on here!
thanks DGZ |
Re: INPUT SIGNAL BOOST ON 002 MIXER?
I should add, on inputs 5,6,7,8
The 002 driver doesn't seem to have the level trims panel you are remembering from the 001. I don't know why this would be, but...
The obvious answer it to boost the level of your source or increase the gain once your track is recorded. Any reason why you can't?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Yup - flommers got it right. If the +4/-10 switch isn't enough you need to increase the volume of the external device going into channels 5-8. If you've maxed out the device in question, you'll need to run it through a preamp or mixer.
There is no longer a software input gain on Digi 002 as there was on Digi 001. I feel your pain, man. I liked the software input gain control on the 001 myself. Probably not the answer you were hoping for, but there it is. John
- System - 12-Core Mac Pro 5,1 3.46 GHz 128 GB RAM Audient iD44 Pro Tools 2020 |
RCA to 1/4 inch cable from dj mixer = no signal | Mix One | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2007 06:32 PM |
Signal boost | Anjel | Pro Tools TDM Systems (Mac) | 1 | 07-26-2006 06:22 PM |
Boost the signal | =GF= | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-19-2004 06:55 AM |
192 I/O input level boost | bruceup | Pro Tools TDM Systems (Mac) | 2 | 04-01-2002 05:41 PM |
how do I boost the MIDI signal when I mix down? | rygar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-22-2000 06:05 PM |
