white noise in guitar amp sims
Im recording guitar direct into an Mbox 2. The clean signal has no noise whatsoever, very quiet. But when I enable an amp sim such as the Sans-amp plug in or Guitar Rig 5, there is an audible white noise in the background. Noise gates cut the noise out during pauses, but when its playing back, you can hear it. Its driving me bananas. Any suggestions? Anyone else ran into this problem? I thought direct recorded guitar would be super clean.
Re: white noise in guitar amp sims
Your direct guitar likely is clean, but every amp sim that I have used, has hiss if you are using any hi-gain patch as they are modeling real amps that also have similar noise(and yes, I find it frustrating as well). I usually insert the EQ III 1-band eq after the amp plugin, set it as a lo-pass filter with the frequency all the way up, and automate it so anytime the guitar fades or stops, the frequency ramps down to kill the hiss. If you experiment with that a bit, you will get the idea, and it works better than a gate Having said that, look over all the parameters on the amp plugin as some have a built-in gate(which may or may not work well).
Also - this tip from SansAmp:
"Keep the Pre-Amp knob at unity gain or higher, to achieve the least amount of noise. For best results, do not set the Pre-Amp level lower than unity gain when the Drive knob is at 9 o’clock or higher. However, if you want a crystal-clear sound and the Drive control is already near minimum and there’s still too much overdrive, decrease the Pre-Amp’s level as needed. Pre-Amp also influences different types of overdrive. For instance, a high setting emphasizes pre-amp distortion (see Boogie® Lead-style setting), as opposed to when Drive is in a high setting, which emphasizes power amp distortion (see Vintage Marshall®-style setting)." More on SansAmp: http://duc.avid.com/showpost.php?p=1359462&postcount=3 Insert a dither plug-in just before the SansAmp PSA-1
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
Thanks a lot fellas. Good to know that its not my gear or anything. And ill definitely try the dither plug in out. Thanks again!
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
Burst of noise (not necessarily white noise) at the end of clips | Swarf | macOS | 9 | 09-20-2012 08:55 AM |
Static noise (aka White noise ) During playback. =/ | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-23-2010 04:06 PM |
"white noise" !!!!!!! | Isaac Jean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-22-2006 12:33 PM |
Pink noise vs. White noise | kcarter | Tips & Tricks | 9 | 08-29-2001 10:42 PM |
