Maximum tracks import from AVID?
Sorry for the "duh" but I'm not a PT user. I'm an editor and I'm preparing a sequence for OMF from AVID. My question is how many tracks can and OMF accept and still all be useable by a Pro-tools system TDM or LE? Any help is appreciated.
Thanks a lot. |
Re: Maximum tracks import from AVID?
I'll answer this as no one else has! so to the best of my knowledge... Le system can only play back a maximum of 32 audio tracks at once! but can have almost unlimited tracks loaded, just 32 tracks only will be assigned a voice. HD tdm systems can have upto 196 tracks but earlier versions were restricted to less! mix system i think are 48 tracks, but don't quote me on this one! it probably depends on how many prosess cards the user has! and again more tracks can be loaded just only 48 voices will be available! OMF from other audio aps can often be a problem, usually different bit rates/sample rates and stereo audio files are the main problems! but with Avid you should have non of these problems. Hope this helps Chris
What's the maximum # of audio tracks I can have in PT10, Non HD in 96K? | Pro Tools Noob Sm. Caulk | Tips & Tricks | 6 | 03-27-2013 04:23 PM |
Maximum Tracks | metrodstar1 | Pro Tools SE and Essential (Win) | 1 | 07-29-2011 10:25 AM |
Import stereo tracks to Avid MC | Roger Stauss | Post - Surround - Video | 5 | 03-23-2011 12:28 PM |
Maximum instrument tracks in LE | allstaar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-07-2010 03:16 AM |
About 24-192 and MAximum tracks. | 1427 | Pro Tools TDM Systems (Win) | 10 | 05-23-2006 08:38 PM |
