Old 09-08-2009, 02:22 PM
AKA AKA is offline
Default Jump to next track - keyboard shortcut ?
After years of doing my orchestral arrangements in Logic, I finally decided to give it (another) try in Protools.
Unless I'm missing something, I can't see a way to jump to the next track/prev with a keyboard shortcut (without having a control surface) ?
Anyone ?
DesignInSound
Old 09-08-2009, 02:48 PM
bradysound bradysound is offline
Default Re: Jump to next track - keyboard shortcut ?
In Keyboard Focus ( Option/Command/1) You can use :/; (DOWN)and P (UP) to move to and from selected regions across tracks. Tab to move forward from region boundaries and tab + shift to select region. When cursor is on beginning boundary, you can Shift/Option/Return to select beginning to end of project.
Hope this helps
Old 09-08-2009, 04:50 PM
AKA AKA is offline
Not quite.
What I'm trying to achieve, is actually selecting the prev/next track. Not jump between regions; let me clear my scenario :
I have created allot of midi tracks, each directed to a different articulation on other PC machines (running GigaStudio etc...). I now want to go thru my midi tracks with a keyboard shortcut. sort of what you would use the arrows in Logic....
To manually select each track with the mouse, is a real creative killer...
I am aware of the fact, that if one had a control surface, you COULD do that. but obviously - I am looking for a shortcut for those without a control surface
Thanks
DesignInSound
Old 09-08-2009, 06:29 PM
Carl Kolchak Carl Kolchak is offline
The shortcuts bradysound mentioned will do exactly what you want if you also have "link track & edit selection" activated (icon next to "link edit & timeline selection" and "mirrored midi editing" icons in the edit window).
Old 09-09-2009, 01:43 AM
tj_davies tj_davies is offline
Hope this helps
Either that. Or you activate the Track Number under the Menu "View" and use the shortcut for selecting the track:
CMD+F and then enter the track number.
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 09-09-2009, 02:14 AM
AKA AKA is offline
Thank you all.
Both methods seems to work.
DesignInSound
Old 09-09-2009, 07:00 AM
crizdee's Avatar
crizdee crizdee is offline
Timothy
Isn't command+F crossfade window?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 09-09-2009, 07:56 AM
AKA AKA is offline
Correct.
It was CMD + OPT + F
DesignInSound
Old 09-09-2009, 09:15 AM
Chris
Ups,
my bad. It used to be Cmd+Option+G. But that was then used for region groups - and as noone actually cried out loud when they changed the shortcut, I think nobody actually uses the track number function. At least I don't know anyone who does.
Timothy
G5 10.8.5
PT 10.3.9 HD2
Record Enable/ Arm Track Keyboard Shortcut? bdilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 08-17-2015 08:52 PM
Keyboard shortcut for audio track record arm? smasyd Pro Tools TDM Systems (Win) 0 04-02-2006 07:57 PM
Keyboard shortcut for the track MUTE button? gbblesph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-20-2005 12:41 PM
track view toggle - what keyboard shortcut? Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-04-2004 03:04 AM
Keyboard Shortcut for Track Size Chronos Pro Tools TDM Systems (Mac) 3 02-12-2002 06:08 PM
