003 automation for Stylus&Omnisphere
I posted the question on virtual instruments question and I did a check on northersounds.com, but the referance to the tutorials from Spectrasonics is not about 003.
I cant figure out is the plugin automation of Omnisphere (and Stylus). I did all the things I did with Strike, but nothing shows up on the 003 when I choose Omni or Stylus. I chose the list of parameters I like to automate, but when I push the knob "inserts" and chose Stylus , none of the parameters chosed from the list is showing. Is just blank The rest of the system works fine. Did somebody figured that out? Thanks in advance |
Re: 003 automation for Stylus&Omnisphere
I cannot belive I'm the only one on the DUC trying this. C'mmon guys...help.
Your question is not as clear as it could be, could you explain again your problem. Do you mean you want to choose certain functions in each of these VIs to automate?
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Hi RussUK and thank you so much for trying to help me.
The problem is like this: I chose the VI and then I can chose which parameter shall be automated, from the list, I move them to the left and save. Then, this should apear on my Digi 003, the same as it apears from Strike, wich I easely figured out. The same procedure I did on Stylus, but the automation knobs and functionsis just not apear on 003. |
So you mean the plugin parameters are not appearing on your hardware control surface?
RussUK< yes, that's my problem
I'm not sure if every Plug-In automatically maps to 002/003, Digi?
I thought all show up...
Maybe Digi can answer? Please. |
as far as I know the functions in stylus as well as omnisphere you want to automate, you have to use the midi-learn function (right click on the controller you want to be automated and then touch the midi controller you would like to control it) I'm not sure if you can assign the controller knobs of the 003 itself to it.
Thanks
What really kicked me is that at one point the 003 shoed some of the functions in the display!!! And then, no matter how mach and how many times I tried...nothing. If it is like this (that it works only with midi-learn)...I am a little bit dissapointed bu... Still wonder if digi can give me a straight answer. PS<I know that is Thanksgiving day in US...so I wait |
Omnisphere and Stylus RMX: sounds are playing back "glitchy" | sylviesongs | Virtual Instruments | 0 | 10-25-2011 12:35 PM |
Stylus & Omnisphere...help? | goga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-28-2009 12:25 AM |
Unexplainable LE crashes with Stylus, Omnisphere | BJammin222 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-20-2009 06:48 PM |
Quantizing to grooves using ProTools, Stylus RMX and Omnisphere question... | Violet | Virtual Instruments | 2 | 05-29-2009 04:08 PM |
PT 8, CPT works! With Stylus and Omnisphere. | Larold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-28-2009 08:34 AM |
