Pro Tools SE White Noise Problems
Has anyone else here had problems with white noise randomly apperaing on this version of pro tools? Almost everytime I record the waveform is correct with what Im playing but on playback it is just deafening white noise!
I am using Pro Tools SE ver 8.0.3 on Windows Vista.... Is that my problem??? As im unsure if vista is supported?? Thanks to anyone who has any help with this. |
Re: Pro Tools SE White Noise Problems
Yes, this sounds much like the problem I am having, only I wouldn't say its white noise - its more like the recorded audio track is insanely distorted. Seems to come and go, and I am not convinced the problem is really in the recorded audio. I think it may just be in the playback.
ok I'm seeing this same problem and it's making pro tools unusable. It just starts sounding like a white noise filter has been applied to the audio. It's been doing this in Avid Media Composer as well. Very frustrating. Just randomly starts happening, everything was sounding great then 10 minutes later everything played back with the white noise filter. Anyone know what's causing this or how to fix it?
I've been using Media Composer for years but this is my first time using Pro Tools. Both record and playback settings are set to 2 channel 44khz 24bit in the windows settings window. windows 7 64-bit pro tools se 8.0.3 with Vocal Studio Mic and I agree with Izyk i think it's just a playback thing, if i export the audio and play it through a different audio device i think it plays fine. thx, jayson |
wow the Pro Tools SE forum is a quiet place.
So is this software just unsupported by Avid? Is it like a demo :) cause i can use it for about 5 minutes before it becomes unusable. And it seems to be happening to a few of us. |
ya its happening to me too....i hate it...someone help me fix it!
Setting Preferences > Audio to "Mixing or Producing" even when recording may help with this issue.
Product Designer Avid |
that does not help the issue!
I was having the same problem on my Windows 7 machine, so I installed the software on an XP machine. So far the problem is gone. The XP machine has 2GB RAM, which I think is the minimum requirement.
Maybe it is an issue with Windows 7? Prestomeco |
Ok since my original post I bought windows 7 seeing as vista isnt supported which seems to have solved my random white noise problem.
However i instead now get a sort of crackling vinyl type noise on my tracks during both playback and sometimes recording. It also appears at random....switching from mixing or producing makes no difference and neither does increasing latency. Any one else have this issue? I have no idea how to fix it |
Thanks for the information. If you are experiencing this issue, could you please post full specifications of the Windows 7 computers. Thanks.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
White noise Pro Tools LE | tuzzound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-21-2011 11:10 PM |
white noise pollution Problems | SeanBrayer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2010 03:28 PM |
Serious problems with freakishly loud white noise! | wedgewedge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-13-2008 02:00 PM |
