Old 03-01-2023, 09:37 AM
sburrows sburrows is offline
Default S3 and dock weirdness
Hi all,
Hope someone here can offer some insight on this issue.
Setup:
Mac studio with 13.2.1
Protools ultimate 2022.12 running under Rosetta
Latest eucon driver..
iPad with latest version of protools control
S3
Dock
Symptom:
When you select a track on the s3 and do anything ie move a fader or change automation status the app and the dock work as expected. Now when I move a virtual fader on the iPad app the fader on both the s3 and the fader on the dock move as expected.
Now when you move the fader on the dock the faders on the s3 and the app don’t do anything.
This is consistent and never works as expected.
All control surfaces have the latest firmware and otherwise function. Just can’t get the dock fader to work as you would expect.
Again the fader moves on the dock when I’m moving it from the s3 or the app, however not from the dock fader…
Any advice would be fantastic…
Cheers….
Old 03-01-2023, 10:19 AM
reichman's Avatar
reichman reichman is offline
Default Re: S3 and dock weirdness
All three faders are moving together over here on a similar system. Are you sure that the same fader is being attentioned? And, you're not in a VCA spill, right?
Mac Studio Ultra macOS 12.6.2
Pro Tools Ultimate 2022.12
Eucon 2022.12/Avid S3 & Dock
AJA Video Driver 16.2.2.5/T-Tap
Dolby Atmos Renderer 3.7.3
Metric Halo LIO-8/4p 6.1.02 [7251] MHLink Driver 3.0.18 (set to jumbo frames)
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-01-2023, 07:41 PM
No not in vca spill..
It doesn’t seem to function when moving the single fader on the dock. But again the dock responds to fader movements on the app and the s3…
Weird… any help you be great..
Cheers
Old 03-02-2023, 02:33 PM
EddieJones's Avatar
If you gently touch the fader, does the track name popup appear in the bottom left of the Control App?
Old 03-03-2023, 06:07 PM
Hi Eddie
Thanks for chiming in.
No it doesn’t…
Any ideas…
Thanks
Old 03-06-2023, 01:55 PM
EddieJones's Avatar
Originally Posted by sburrows View Post
Hi Eddie
No it doesn’t…
Any ideas…
Thanks
Then I suspect the fader touch is not working. You can try cleaning the fader. First blow air whilst moving it, then if that doesn't work use deoxit(sparingly)
Dock + Raven VS Dock + S1 emankayker Avid Pro Mixing General Discussion 0 11-26-2020 03:30 PM
Dock/S1 VCA Spill Weirdness - or is it just me? barden Avid S1, S3, Dock and Control App 3 02-17-2020 08:13 AM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
OMF Weirdness LucidMJW Post - Surround - Video 8 10-16-2009 02:02 PM
IR/1 weirdness jeff markham Pro Tools TDM Systems (Win) 6 09-01-2006 12:54 AM
