Old 02-12-2023, 04:51 PM
basehead617 basehead617 is offline
Default Avid Control faders and meters sluggish/intermittent
Using Avid Control on iPad Pro 2nd gen (latest iOS) via Wifi to PT Ultimate (2022.12) on a Mac Pro 7,1 (latest Monterey)
Faders will ‘catch’ while trying to do smooth movements then jump an inch or so. It’s wonky on the app side too not just in PT.
Meters have the same behavior where they update intermittently.
Network is 5 ghz with full/strong signal and nothing else using it simultaneously. No QoS enabled.
Happens in a brand new project with 1 channel, so it’s not overloaded.
Logic Remote Control app on the same iPad has no issues controlling Logic on the same Mac Pro without sluggishness.
Ideas?
Old 02-19-2023, 06:24 PM
Default Re: Avid Control faders and meters sluggish/intermittent
bumping this… i can’t be the only one?
guess i’ll make a support ticket if this goes nowhere.
Old 02-20-2023, 07:21 AM
reichman's Avatar
reichman reichman is offline
I've seen this in a crowded studio with a ton of RF interference making the Wi-Fi wonky. You could try running the iPad on ethernet, but that doesn't explain why Logic is working well.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-20-2023, 01:15 PM
s.d. finley s.d. finley is offline
You aren't the only one. New Eucon is buggy. I have had the meters disappear and then reappear the next day. Nothing changed in my setup, same wifi network too. I have also had the faders on the Control App have massive lag. Next day it's fine. I cannot get these issues to repeat.
sdf
www.sugarhillstudios713.com
Old 02-21-2023, 09:49 AM
EddieJones's Avatar
Nothing has changed in this area of code and these symptoms point to network related. If it was a bug in the software then I would expect 100's of posts about it. (FYI comparing the Logic App is not a true comparison as the EUCON protocol requirements are night and day)
If you Collect the logs and send me a link to download them we can take a look to see if this is the case or now.
Old 04-16-2024, 03:20 PM
budster budster is offline
Hey guys, one of the rooms in the nine room facility at work on fast. Intermittent issues both on the iPad and on S3 and Dock surfaces. Screens, kind of flashing on the iPad and Feder is going up and down in LEDs on and off. It's almost like it's net work or conflict and it's on everything connected to Eucon. The Eucon network is seperate from IOT and general production like our other rooms.
Could a program like ChronoSync or other be interrupting things?
PT 2023.12 Ult
Eucon 2023.11
Mac Os Monterey
Intel Mac Pro Tower w/128GB Ram
PT Ult 2023.6 HDX2
Mac Studio M1 Maxx
OS 13.2.1 64GB Ram
S6 32 fader 2022.9
Avid Control App - Meters Yellow and Can't change pgstudio Avid S1, S3, Dock and Control App 0 05-10-2022 06:53 AM
Avid Control: Meters in monitoring tab JanuS Avid S1, S3, Dock and Control App 0 10-31-2020 03:11 AM
Avid Control, Meters not working on iPhone 8 bsteeve Avid S1, S3, Dock and Control App 8 12-11-2019 11:17 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Sluggish meters in 6.4.1 Doug Beck Pro Tools TDM Systems (Mac) 2 11-20-2004 08:08 PM
