Ways to view gain reduction?
Is it possible to view gain reduction on the D-Command next to pre or post fader metering on the meter bridge of each channel that has plug in compression or limiting inserted on it? Thanks!
Luke Rohwer Acacia Recording & Production www.acaciarecording.com Luker[at]acaciarecording[dot]com Studio 301-703-0035 |
Re: Ways to view gain reduction?
any time a strip is in 'Dyn' mode the meters switch over... you also need to make sure "GRChan" under the console meter prefs button is set to on...
hmmm... we might have different firmware versions on the ICON ... on mine: when you hit meter in the console prefs section GRChan is on the lower right softkey... maybe its on the second page of console meter prefs (just hit 'meter' again)?
if you hit the 'dyn' button on the channel strip so that the encoders show the dynamics plug parameters, thats when the meter up top switches over... hope that helps. |
damn, sorry... i skipped over that very important part! i'm on a d-control... doh!
Thanks for trying!
Display of the amount of gain reduction on the meterbridge in insert mode is I afaik D control only.
However, and I'm not 100% sure of this but in Custom Fader Plugin mode I think D command will display all plugin metering as well. So if you were to open up a dynamics plugin in CF mode then you would see the GR channel as well You should check this ...
Chris Lambrechts Applications Specialist- Live Sound |
View Gain Reduction on D-Command? | Logichead | ICON & C|24 | 3 | 12-13-2016 10:08 PM |
Gain Reduction Meter only HD? | flautista | Pro Tools 11 | 10 | 05-26-2014 01:23 PM |
Gain reduction meters in Native 1st use ! | Nearlymen | Pro Tools 11 | 31 | 12-30-2013 12:34 AM |
Gain reduction display? | audioluche | ICON & C|24 | 4 | 02-06-2012 09:58 AM |
ways to monitor dBV, dBU and db SPL during the mix (for precise gain structuring) | weighbor | General Discussion | 2 | 06-25-2010 10:13 AM |
