Can't export as stereo interleaved/stereo only multimono?
For some reason today PT won't let me export regions as stereo or stereo interleaved files!! it will always export as 2 stereo .L and .R files. Yesterday it worked fine and i need to drag these files into a sampler etc What gives? whats happened? i've re-booted. Chris
Re: Can't export as stereo interleaved/stereo only multimono?
What do you mean by export?
Jim Carroll |
regions menu/ export regions as files
Did this most of yesterday and exported stereo files to drop into Kontakt, today i select stereo and get 2 mono files Chris
Check the region names end in .L and .R -- and I've found that both mono source files need to be in the same source path or you get an error.
Rail
Hope it helps, Timothy |
I know this as the clear find-command, which works only as a 'display all'-command if there was a FIND (shift cmd F) before
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Not sure whats happening here but i've shot this video so maybe somebody can see where its gone SNAFU The .L and .R of each region seem to have become separated? All these regions were time stretched with sound shifter and then cut on transients before exporting regions to a folder for the sampler. In this vid the blue regions are the one's that are separated. the pink region is what i've been doing all the previous day with no probs!! Time shifter is set to "multi input mode" if that makes any difference, though i haven't changed it from the previous day.... http://www.youtube.com/watch?v=sd6YobNJpSI Chris
Jeeeezzzz Chris... Ghost in ur machine as of late
Probably the same blighter that went down my infiniband cable into my chassis and trashed one of my Process cards on thursday.
Must be some explanation to this export regions problem! Chris
No Stereo Interleaved Export Option??? | ianbee | Pro Tools 10 | 3 | 12-22-2012 06:21 PM |
OMF interleaved stereo | aptmusic9 | Post - Surround - Video | 7 | 03-15-2012 12:04 AM |
.WAV stereo file export not STEREO! | RandallYoung | Pro Tools TDM Systems (Mac) | 10 | 11-24-2006 01:00 AM |
export selected as stereo interleaved not happening | love666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-29-2002 12:30 AM |
interleaved stereo--what is this | norie | Tips & Tricks | 5 | 03-21-2000 08:28 AM |
