Old 12-11-2006, 01:57 PM
alx002 alx002 is offline
Default Protools 7.3 LE STILL BAD MIDI BEAT CLOCK
Good work Digi !!!!
Protools 7.3 is still BAD to loop in MBC !!!!!! My MAQ DOEPFER stops playing after one LOOP !!!!
MACPRO BI 2,66 +5Go RAM+ OS 10.6.8 FRENCH SYSTEM + DIGI002 RACK Protools 9.06
www.myspace.com/alx002
Old 12-11-2006, 02:13 PM
Default Re: Protools 7.3 LE STILL BAD MIDI BEAT CLOCK
Thank DIGI !!!
I won't buy your update at this moment !!!
Old 12-12-2006, 07:14 AM
Old 12-12-2006, 07:42 AM
halfguard halfguard is offline
im curious to what your doing because i dont have this problem. i use an mpc 1000 with beat clock and no problems.
Old 12-12-2006, 08:06 AM
Make a loop in Protools : measure 1 to 3 ( 2 bars)
Active PLAY LOOP
Send MBC to MPC
ANd PLay ........ Normaly the MPC will Lost SYNC after 1 or 2 loops.......
If you want to check the sync with PT : record a KICK track and loop this track while listening the return of the MPC .
I don't have any MPC1000 . MPC1000 is very recent so it could work with it
I tested on MPC2000 , TR909, REVOLUTION, XBASE09 jomox, MAQ16/3 Doepfer and all these gears are not compatible with the MBC of Protools !!!!
But the REVOLUTION , the MAQ and the XBASE are very recent too and they don't sync to PT ( IN LOOP PLAYBACK MODE)
Old 12-15-2006, 01:53 PM
Can a technician Digi support answer to me?
Will you ONE DAY correct your MIDI BEAT CLOCK like in the previous version 6.4 ?
Old 12-15-2006, 04:18 PM
DigiTechSupt's Avatar
We were able to reproduce the problem you reported with a Yamaha SY85 in Song Mode. That device (and others) work fine in Pattern Mode. Can you try that and let us know your results?
Avid Audio Tech Support
Support FAQ
Old 12-18-2006, 03:17 AM
I will test with the TR909 in SONG MODE !
Notice that the MAQ16/3 Doepfer does not have SONG MODE : and this Sequencer STILL stop at the end of the LOOP.
Notice also that it is impossible to compose BEAT in SONG MODE on a DRUM BOX ;-)
Old 12-18-2006, 12:12 PM
Still does not work with a TR909 ROLAND even in SONG MODE !!
PLEASE put the ORIGINAL MBC FEATURE PT 6.4 AGAIN !!!!
You could call a LOGIC AUDIO APPLE programmer to know how have a good MBC ?????? no ??????
Old 12-18-2006, 12:29 PM
flommer flommer is offline
Dude, you're funny......
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
MIDI Beat Clock? guitarless Eleven Rack 3 10-24-2010 03:39 PM
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
Triton...is MIDI Clock difrnt than MIDI Beat Clock BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2006 12:24 AM
Slaving ProTools with Beat clock cybernaga595 MIDI 1 03-28-2004 05:12 PM
Protools Lock To MTC or Midi Beat Clock? nozza1 Pro Tools TDM Systems (Mac) 10 05-30-2001 03:30 PM
