Problems with Pro Tools LE 8.0.4; No audio in headphones, mic signal peaking
Hi, I've tried searching for a thread where this problem is being brought up, but I haven't find any as of yet..
This problem came out of nowhere, Pro Tools was working just fine yesterday but now whenever I open a session and try to listen to the mix, Pro Tools starts playing it and I can see activity on all the tracks but there is no sound in my headphones and when I activate an audio track for recording the input audio signal peaks.. What can I do to fix this? |
Re: Problems with Pro Tools LE 8.0.4; No audio in headphones, mic signal peaking
1st of all you could try to click the defaust settings on each tab of the I/O window. If that gives you a problem, make sure your output is set to L&R. As for input volume, this can be adjusted useing the (according) knob on the front of your digi box.
www.rickqueststudio.com |
I have the same problem, and I tried those fixes and they don't work, any other ideas?
No signal through right channel in headphones... | stephesk8s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-22-2011 07:15 AM |
No audio signal or midi signal after pro tools 8.04 upgrade | allgenres | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-01-2010 08:58 AM |
Mbox 2 + garageband = peaking signal | dfa1977 | Pro Tools M-Powered (Mac) | 0 | 12-22-2006 06:50 PM |
mbox source 1 peaking/no signal problem | sknife | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2006 10:38 PM |
help!: Tracking mic gains off but signal peaking?? | mach-1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2005 09:39 PM |
