Old 02-27-2015, 10:11 AM
bcwiz's Avatar
bcwiz bcwiz is offline
Default Write to previous/next
Any Pro Control key combos for Write To Previous (or punch) Write To Next?
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 03-03-2015, 02:46 AM
fm_xtk fm_xtk is offline
Default Re: Write to previous/next
Yes you can. CTL/CLUTCH + RTZ writes to the beginning, CTL/CLUTCH+ GO TO END writes to the end, CTL/CLUTCH+SHIFT+RTZ writes to entire selection.
It's a bit of an acrobatic exercise unless you use TRIM or LATCH modes. I prefer using APPLE+/ (write to current) as it is a single hand shortcut.
Look it up on p. 185 in the manual
2x Hackintosh X79
HD7 Accel PCIe, Magma EB7 chassis
PT 10.3.10 Mac OS 10.9.5
SSL Delta Link HD 160 I/O
COCKOS REAPER (latest)
RME MADIFX (192 I/O)
ProControl (32 channel)
Old 03-03-2015, 07:19 AM
bcwiz's Avatar
Yes thanks. I was specifically looking for the Write To Previous/Next Breakpoint (manual write). Also Write To Previous Breakpoint will write back to the automation punch point without having anything highlighted.
I do it from the automation window but I was hoping for a shortcut.
Brian Campbell
Old 03-03-2015, 08:26 AM
I don't think that is supported officially. I had been looking for the exact same thing as well but for me it's not that big a deal to write so a selection.
However, I have found a workaround to write back to the punch point if that helps:
1) Start playback by using "7" (play from insertion). This also works via AUDITION+POST
2) Start writing automation
3) Press CTL/CLUTCH+SHIFT and RTZ.
For some reason it doesn't work with regular PLAY or SPACE BAR.
This way you can write back to the insertion point but I think it writes to end as well so if you have automation later in the track it will get overwritten.
Might be worth checking whether the function you are looking for is available on the EDIT PACK.
2x Hackintosh X79
PT 11.2.1 and previous version... TheEdster75 Pro Tools 11 3 09-29-2014 07:12 PM
MIDI CC for Next/Previous Rig CoiLive Eleven Rack 6 05-30-2011 09:34 AM
Saving to previous versions SoulRiderLeo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-16-2008 12:18 PM
Previous post 190Franklin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-20-2006 09:55 AM
Using previous takes from BIN BigRay Tips & Tricks 5 06-08-2005 03:37 AM
