Re: Gibson kills off Cakewalk
Sent from my Pixel XL using Tapatalk |
Found a good article about exporting SONAR files to OMF format.
https://www.cakewalk.com/Support/Kno...r-Applications Exporting SONAR Projects as OMF Files for Use in Other Applications Last updated on 3/28/2016 An Ounce of Preparation... If you plan to export a SONAR project to another program that can read OMF files, it pays to consider three things before you start your SONAR project: · Sample rate and audio bit depth of the target system · Number of tracks the target system can handle · SONAR and most other audio programs do not include Video in OMF file While sample rates and bit depths can be converted after you export a project, it saves a lot of time to avoid conversions, if at all possible. To Prepare a SONAR Project to Export as an OMF File 1. Make a copy of the project you want to export, and then only work on the copy to prepare for export. 2. If you have any MIDI tracks you want to export in the project, either record them as audio tracks, or put them into a Standard MIDI File that the other program can read. 3. Delete any tracks you don't want to export. 4. If you want to export volume or pan automation that is represented in SONAR as volume and pan envelopes, you will need to Edit-Bounce to Tracks or Edit-Bounce to Clips to mix the envelopes into new audio tracks or clips. 5. If you want to export the sound of any plug-in effects that you have patched, select the tracks that have the effects patched, and then use the Process-Apply Audio Effects command. 6. Create a text file to send along with the OMF file, detailing the tempo and any other important information about the project. Exporting SONAR Projects as OMF Files After you prepare a copy of your project to export, exporting is straightforward. Check with the engineer at the target studio to see if there are any special instructions for exporting, such as whether they want the file in Windows (RIFF Wave) or Mac (AIFC) format, which you can choose in SONAR's Export OMF dialog. If you've booked time at the studio, arrange to have your project played and inspected at the studio the day before your session, to be sure your project is as expected. To Export a SONAR Project as an OMF File 1. Use the File | Export | OMF command. 2. The Export OMF dialog appears. 3. Enter a File Name (maximum 64 characters-SONAR limits name length for ISO CDR compatibility), and in the Save As Type field, choose OMF Version 1 or 2. Most applications expect Version 2, but check with your engineer. 4. Audio Packaging: usually you should choose Embed Audio Within OMF, which includes the audio data in the OMF file. But you should check with your engineer. 5. Split Stereo Tracks Into Dual Mono: see what your engineer wants. If exporting a 24-bit project to a Pro Tools system, enable "Split Stereo Tracks Into Dual Mono," as some Pro Tools systems do not support 24-bit interleaved stereo files. 6. Include Archived Tracks: you can choose to include archived tracks in your exported file. 7. Mix Each Groove Clip As A Separate Clip: if you have several Groove Clips in a track SONAR exports them as one clip unless you check this option. If you check this option, SONAR has to do a separate export operation for each Groove Clip in the track, which is very time-consuming. If you only have one Groove Clip in a track, and you have rolled out numerous repetitions of the clip, SONAR exports a single clip that is the length of the original clip and all the repetitions, which is not a time-consuming operation. 8. Audio Format: ask your engineer what format the studio uses, Windows (RIFF Wave) or Mac (AIFC). 9. Click the Save button. 10. SONAR exports the project as an OMF file. You can also open OMF files to SONAR from Pro Tools and other programs that can export OMF (File-Open command). Read the tip on importing OMF files into SONAR. |
Goodbye Cakewalk!
http://forum.cakewalk.com/Cakewalk-A...-m3687511.aspx
I used Cakewalk ProAudio years ago. Kind of sad to see this happen.
Apple M1 Mac Studio (base model) ProTools Carbon w/SSL XLogic MADI-AX Instagram: https://www.instagram.com/sparkletune/ |
Re: Goodbye Cakewalk!
M&A never benefit the consumer. Big business wins again.
This is really sad to me. I used Sonar from Cakewalk ProAudio 9 through Sonar 1-8.5 and I am sad to see this happen. The developers were really on top of innovation and creative ideas. I left to Pro Tools out of the need for stability, dsp, and compatibility between local studios. I do love Pro Tools, but it is always sad to see a company go out of business that had so much passion to innovate. They were ahead of their time in many, many, aspects.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
It's very sad...
PC i79700K 4.8Ghz 32Gb ram Nvidia1050 Win 10 64 SSL MX4 |
Looks like Gibson did to Cakewalk what they did to Opcode. IMHO Studio Vision was probably the best DAW there ever was and I can only imagine what it would have become.
Since I was/am a registered user I would occasionally get email from them. When they were offering a lifetime license with free updates I figured something was wrong.
It's a shame that my first post on this forum comes as a direct result of the events at Cakewalk but I need to make contingency plans for the future, so here I am.
I feel for the Cakewalk employees and the many faithful users, especially after 30 years of software development, but having read Russ Hughes insightful 'Critical Lesson' article on 'Pro Tools Expert', I guess we all know that nothing lasts forever. Onward and upward. |
Goodbye Cakewalk!
Gibson should have at least tried to pawn its IP over to someone- heck I bet Propeller or Reaper would have taken it...
IIRC some of the zip code folks ended up at Cakewalk. Ironic.
Gibson buying Cakewalk | musicman691 | General Discussion | 11 | 09-26-2013 04:08 AM |
Gibson, JBL, Dr. Z... | WildFrog | Buy & Sell | 0 | 11-12-2012 07:10 PM |
OT... I need an Gibson LP | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-23-2004 04:51 PM |
R.I.P. Don Gibson | BAJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-20-2003 06:34 PM |
Gibson MaGic | amdo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-07-2001 09:21 AM |
