Shift piece of Song with Tempo, Meter and Markers
Greetings. New member here. I'm scoring my first documentary and producer is changing the length periodically. I need to insert additional music in this 1/2 hour-ish long session. So, I need to shift everything wholesale, later in time i.e. audio, midi, tempo changes, meter changes and Markers. Can't seem to swing it! tempo, meter and markers are the issue. Tricky and tedious and can't seem to find a single approach in manuals, or "help". Any thoughts? Thanks!
Re: Shift piece of Song with Tempo, Meter and Markers
I don't know what version you are on, but can you "select all" in groups and extend the time selection up into the tempo and marker lanes and then bump them over?
bookerv12 |
You have to use "insert time" so place the cursor where you want the extra bars or time, (whichever one you are working to) then go to menu > Event >Time Operations> insert time. Select the amount of bars or minutes you want to inset press apply, and Voila your entire session will move, creating a new region. Same can be done with "cut time" to remove regions and shorten sessions etc. Chris
How to shift markers along with the clips? | stpete111 | Pro Tools 10 | 9 | 06-02-2013 08:27 PM |
Preserving Markers/Tempo/Meter Settings | ratava | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-31-2007 01:53 PM |
Meter and Tempo Change Markers | 1511 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2003 04:01 AM |
How do you link and shuffle all tempo & meter change markers | 1511 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-13-2003 12:22 AM |
Memory Markers and tempo events won't move when I shift audio and MIDI tracks | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-23-2002 10:14 AM |
