convert mac session to avid-friendly omf
I'm trying to export my pro-tools session to an avid system that can import my tracks (via omf). Does this work? Any pitfalls? What I should I look out for? Thanks a ton!
Re: convert mac session to avid-friendly omf
Hi mrmann ,
you can convert a PT session to a omf sequenz with digitranslator from digi. regards jochen |
Hello,
As mentioned you can use DigiTranslator to export tracks from Pro Tools as an OMF document. With DT installed: -Select the tracks you would like to export -Go to FIle > Export Selected Tracks as OMF -Check "Enforce Avid compatibility" -Confirm that the Target Project timecode format is correct -If you are going to a Mac based Avid use either SDII, AIFF or Embedded -For a Windows based Avid use either AIFF, BWF or Embedded -Hit ok and name the OMF On the Avid: When importing a sequence that was exported from a Pro Tools session (Export Selected Tracks as OMF), always drag the resulting audio media files into the OMFI Media Files folder on the Avid first. Then go to File > Import OMF. I hope this helps. Mike |
G-Force will NOT convert to AXX they want Avid to make a wrapper-plz read email sent | shamanrock | AAX Plug-ins | 15 | 05-14-2013 05:14 PM |
LE (CPTK) Plugins (A friendly reminder to Avid) | ChazC | Pro Tools 11 | 11 | 05-03-2013 07:47 AM |
Way to Convert Session Bit/Sample Rate??? From Within Session??? | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2011 09:48 AM |
Convert Mac (LE 5.x) session to PC (LE 6.9) ... | bigbottombass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-06-2005 12:06 AM |
What's the best way to convert a 48k session to 44k ??? | dw | Tips & Tricks | 4 | 03-13-2000 07:57 PM |
