Old 05-06-2009, 04:21 AM
zbocelle zbocelle is offline
Default Anyone using a Digi002 with a MOTU Traveler - ADAT?
I currently have the traveler set at 48 with the Digi002 clocked to it. That part is fine. ...but I get no sound through digi into PT. If I set one of the Traveler mixes to output over ADAT1-2 I get that. ...but discrete ADAT channels 1 thru 8, nothing.
If anyone is running this type of set up and has any info I'd greatly appreciate it.
Old 05-06-2009, 04:22 PM
ChuckS ChuckS is offline
Default Re: Anyone using a Digi002 with a MOTU Traveler - ADAT?
Maybe this thread will help. Most of the MOTU firewire units are similar in their routing with CueMix, ADAT I/O, etc. Even though the thread does not specifically reference the Traveler, the setup with the mix busses is the same for ADAT.
http://duc.digidesign.com/showthread.php?t=244274
Old 05-07-2009, 05:09 AM
Ahhhhh!!! Chuck!!! Thank you. I was out on motu and i guess i was to focused on the traveler unit in my searches. This makes perfect sense and I was almost right there with routing mix 1 to adat1-2. damn this little brain!!!
Motu Traveler as ADAT to AES/EBU converter Minty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2009 02:16 PM
Motu Traveler connected to Digi002 through Optical Violet Sun Electric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-21-2006 11:11 PM
Digi002 Rack & MOTU 828mkII via ADAT boc12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2006 05:02 AM
Digi002 Rack & MOTU 828mkII via ADAT boc12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-28-2005 05:30 PM
Motu Traveler & PT LE Terry Dycus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-08-2005 07:31 PM
