Old 12-28-2001, 03:12 PM
francis eyre francis eyre is offline
Default using virus in Logic (again)
thanks to those who replied previously
I now understand that both OMS and the built in midi drivers both need to be switched on and that you use the plug-in on an aux. track
what I don't get is how you route the external midi signal to that aux. track. In the PT software you simply set the output of the midi track to 'virus'. can you do the same thing in logic??
thanks again
Old 12-28-2001, 03:19 PM
plenky plenky is offline
Default Re: using virus in Logic (again)
this is not very elegant in logic, but it works really good.
you will have to create a new instrument in any enviroment. then, after the virus is instancinated in an aux track, you can select in the parameters section of this instrument (you have to select the instrument again in the environement you created it!) virus as your midiport.
then you have to create a track in the arrange window and select the newly created instrument( should be in the subfolder"Midi Instruments")
hope that was clear ....?
Old 12-28-2001, 08:02 PM
john1192 john1192 is offline
what may help is naming the new aux channel something familier...ie: name of synth or whatever....
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-02-2002, 11:06 AM
thanks to both of you
Old 01-02-2002, 11:35 AM
Nick Jarl Nick Jarl is offline
You dont have to put the virusplug onto an aux track anymore. Any audio track works fine. [img]images/icons/smile.gif[/img]
Nick Jarl
8-Core 3.0 8GB HD3Accel 10.6.4 PT8.1cs1 192I/O
Old 01-02-2002, 11:49 AM
how do you set virus as the midiport in the environment? when I try this I get a choice of 'Conn1 ' 'Conn 2' or 'USB'?
thanks
Old 01-02-2002, 04:06 PM
Marc Rosenberg Marc Rosenberg is offline
This is how I do it:
Choose "Use Built-in & OMS" in MIDI Interface communication
Create a Virus Instrument in your Environment, map to Virus1a
Create an Aux Track and instanciate the Virus TDM Plug-in
Virus will show up in the list of available MIDI Instrument choices in the Arrange on a Track. Make sure you are choosing the appropriate instrument on the track in the Arrange Window.
You can email me at alaluna@pacbell if you need
Pro Tools & Logic Programmer, Engineer, Consulting, Education
Old 01-05-2002, 04:27 AM
thanks again for the advice. The village idiot has almost got this sorted now!
I'm now getting midi into the plug-in (flashing light) but no audio out. Any idea why this might be?? Is there any special routing necessary?
Old 01-07-2002, 09:36 AM
do you hear sound when you click on the Virus keyboard?
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Virus TDM and Logic / DP georgiegman Pro Tools TDM Systems (Mac) 4 09-01-2006 03:47 AM
Virus and Logic TDM? john1192 Pro Tools TDM Systems (Mac) 2 11-30-2001 02:00 PM
Virus and Logic JLEpperson Pro Tools TDM Systems (Mac) 7 06-20-2001 10:50 AM
Virus and Logic JLEpperson Pro Tools TDM Systems (Mac) 1 03-07-2001 09:52 AM
Logic 4.5 - Virus TDM arbora Pro Tools TDM Systems (Mac) 4 07-31-2000 08:17 PM
