Old 09-14-2018, 11:59 AM
BiggDogg BiggDogg is offline
Default Buzz and Hum on Audio Track
Windows10 ProTools 12.7.1 Focusrite interface 6i6
I am trying to record a bass track using Line Out from the bass amplifier. I am getting a very loud 60hz line hum and a loud buzzing sound as well.
We have tried different cords, ground switches, different outlets, different multiple outlet boxes and tried to get rid of the buzz and hum using EQ.
Can anyone give me a simple solution to get rid of the buzz, a filter, cord etc.? It only occurs on Audio tracks, never Instrument tracks.
Thanks.
Old 09-14-2018, 01:06 PM
albee1952 albee1952 is online now
Default Re: Buzz and Hum on Audio Track
Have you tried a good direct box? Passive boxes(like the Radial JDI) have a transformer to provide isolation from ground loops(which is likely what you have). Other options: plug the bass amp into the same outlet as the computer and interface. Use an XLR barrel that is wired as a Pin-1 lift(pins 2 and 3 are connected thru, but pin 1 is not). Both of these ideas can often fix a ground loop.
Sometimes, its actually coming from the instrument, especially if it uses single-coil pickups. I have a Peavey Millenium bass with the typical Jazz-bass pickups that are single and it will hum pretty bad if I use 1 pickup, but they wired it so using both together creates a humbucking setup, making it quiet. But...all guitars and basses buzz in my control room because of the rack and my only solutions are; move the player into another room, or run noise reduction plugins after tracking is done. Izotope and waves have some very good plugins for that and both are available for free trial(commit the track before the trial period runs out).
If the noise is higher frequencies and only is heard when a note fades, you can insert the 1-band EQ III. Set it as a low-pass with the frequency all the way to the top. Automate the frequency parameter and as notes fade, have the freq knob slide down to 1-2 KHz to roll off the buzz(this works great on strat/tele guitars with noisy single-coil pickups).
Old 09-14-2018, 02:04 PM
..and you can try forgetting the amp all together and just go into a DI with the bass and use an amp sim plugin if needed. The amp may be contributing to a ground loop, or just amplifying hum already being picked up by the bass. The bass may still want a good isolating/transformer DI (which the DI on your interface is *not*).
Likely no surprises here, you should read up on ground loops and how to solve them.
There is no hum on instrument tracks because there is no recorded audio on instrument tracks.
Old 09-14-2018, 02:48 PM
dg27's Avatar
dg27 dg27 is offline
I'm a bass player first, so bass for me is a priority.
I've had great results using a Tech21 SansAmp. I always have two tracks for bass: one is the XLR, which is direct (untreated). I run another line out of the regular output, which includes the SansAmp settings. I find by blending the two I can find a very good balance and the tone I want.
Old 09-14-2018, 06:34 PM
If that gives you what you want, then its a perfect method. For me, I track bass direct with a good DI, or straight into the instrument input of a Neve clone. I also send the bass from the DI track to an AUX track with Amplitube's SVX bass amp plugin(usually with a tweaked B15 model). Then in the pedal section, I add a distortion pedal(this is bypassed during tracking as its not pleasing in headphones). When its time to mix, the distortion pedal gets turned on and the bass pops out really nicely
Old 09-15-2018, 06:01 AM
Fender Jazz bass with the S1 switching into a UA 610 into the line in on my 11 Rack. That way I bypass the signal drop inherent in going into the 11R's guitar input. That and for some reason my bass doesn't get along with the input impedance on the 11R guitar input.
Jack
QAPLA!
Old 09-15-2018, 06:49 AM
Thanks to all who have replied to me. We will be considering all of the suggestions.
Thank you!
Audio input buzz lawmusic Windows 0 11-29-2011 03:45 PM
Help Midi Track Buzz. batchmister1 Pro Tools M-Powered (Win) 4 11-13-2008 06:09 AM
Terrible buzz on the end of track Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-30-2005 04:02 AM
Buzz Audio pre's Bookerv12 Pro Tools TDM Systems (Mac) 12 10-04-2003 03:53 AM
buzz when internal audio out is used Paul Southworth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-08-2003 11:43 PM
