#41
Re: Eleven Rack through Stereo Power Amp
As for my setup, when going through the mesa, I do not use cab sim. I prefer the sound of the celestions. When I want to play through PT, I dont even turn the mesa on. Just the USB out to my computer and use the cab sim. I like the 2x12 cab sim the best.
I was looking at all of the goals that you listed and the way that I have my mesa setup, I can achieve all of these. Right now though, I only have a pair of decent desktop speakers that I have the headphone jack connected to. If I get a pair of nice powered monitors then I would disconnect the mesa and use the main outs of the 11R. Sean |
#42
I think the main advice was try and see what sounds best, which is what you did. A lot of the thread was about why often a power amp will sound better driven by the line level Main outs and not the instrument level amp 1/2 outputs. But there is often gain staging to play with as well, as in the case of the Mesa 50/50.
If you need the main outputs as Pro Tools monitors then your hands may be more tied, but if you have multiple interfaces it's easy to hang the Eleven Rack off another interface and use it as an outboard processor and still use it's main outs to drive a guitar power amp/fx loop input. Make sure as well you understand the cab resonance setting--see the user guide write up on this. Darryl |
#43
Just read your response Darryl and I agree. If there is not a second interface, then we would have to choose one or the other for the main outs.
Sean |
#44
Darryl
I just uploaded the rig onto www.elevenrackpresets.com. The name is of the rig is called Seans Crackly Tone. Check it out and let me know what you think. Thanks Sean |
#45
Also have you tried to reamp a dry guitar track? If so can you post the dry guitar track online somewhere. Darryl |
#46
Darryl,
I think that I found out what the issue was. Most of the DC amps ( i like the DC Modern) I'm finding are the ones with the extra noise. Even with the gain lower than usual, there is still the noise. I made a completely new rig almost identical to the one that I sent the sound sample of, but I used the Treadplate M and the V model. No noise at all. I even have the gain higher than that of the DC Modern. I think that with my guitar setup, it just does not agree with those amps. Very satisfied with the sound now. Thanks for being interested in helping. Now if I could only get the Big Fish loops to show up in the workspace window on PT!! Sean |
Eleven Rack with a power amp setup | YYR123 | Eleven Rack | 10 | 01-28-2014 01:40 PM |
Eleven Rack Power Plug | Jemini | Eleven Rack | 8 | 11-10-2012 03:46 PM |
Eleven Rack Stereo Delay Trouble | scottya | macOS | 1 | 03-20-2012 08:11 AM |
Eleven Rack Freeze At Power On 8-0 | brianiac5150 | Eleven Rack | 3 | 11-05-2011 09:48 PM |
Eleven Rack with Power Amp Volume | killdozer | Eleven Rack | 7 | 02-19-2011 03:45 PM |
