Eleven Rack Freeze At Power On 8-0
OK...I'm not panicking yet, but the other night I hit the switch on my Furman, which powers on my Eleven Rack, whose switch is always on and it fired up, but simply froze on the first/welcoming Eleven Rack screen with the bar scrolling across the bottom (it just kept scrolling, left to right). I waited several minutes for it to flip over to the preset view as it usually does, but it didin't. I ended up flipping the Furman switch off, waited a few seconds and flipped it back on to the Eleven Rack powering up as normal.
A quick search here doesn't seem to reveal anyone else having this issue, so I thought I'd ask: anyone else have this happen??? Please don't die on me my beloved Eleven Rack.
THoM Facebook |
Re: Eleven Rack Freeze At Power On 8-0
Did you recently update your drivers or messed with the Eleven Rack drivers on your PC/mac?
I ask because I had a similar problem when an update didn't fully take (power shortage at my house) and I started up again and my Eleven Rack totally froze ... I completed/restarted the update and it came back as usual ... This was in the first month or so when I got it and hasn't happened since so it was a "freak occurence". Still, these kind of things make your heart stop for a moment ... If it happens again I'd reset your firmware and see if happens again And I don't know but maybe you need to manually turn off the Eleven Rack? I'm a total n00b at these things but it might be like a computer thing where the Eleven Rack needs to power itself off in a correct way ... Maybe someone knows something about this?
Guitars: Schecter C-1 Blackjack ABSN, Ibanez RGA 121 Amp: ENGL Ritchie Blackmore Effects: TC G Major 2 Awesome: Eleven Rack (with EXRP)+ M-Audio Bx8a's |
@Mister_Riff
At the time this did this, the PC it's connected to was not even on and I have not altered anything - other than presets, at all. Like I said; it hasn't happened since, but I've only had it on a few more times since then. I plan to spend some time with 'er today. Thanks for your response.
THoM Facebook |
FWIW, I turn on each piece of hardware in stages, usually a second or two between them rather than having 'one switch' fires up all at once.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Eleven Rack with a power amp setup | YYR123 | Eleven Rack | 10 | 01-28-2014 01:40 PM |
Eleven Rack Power Plug | Jemini | Eleven Rack | 8 | 11-10-2012 03:46 PM |
Eleven Rack through Stereo Power Amp | brewboy73 | Eleven Rack | 45 | 07-31-2012 04:35 PM |
Need advice on using Eleven Rack with tube power amp plus a 4-12 cab | mick828 | Eleven Rack | 8 | 10-05-2011 05:18 PM |
Eleven Rack with Power Amp Volume | killdozer | Eleven Rack | 7 | 02-19-2011 03:45 PM |
