PT10 Not Playing/Recording
Hello friends. I recently got a new computer hoping to run Pro Tools 10 with it. The problem is, it doesn't seem to like my interface. I'm using a Zoom R16 interface. When I load up a session and try to record a track, the play, pause, and stop buttons start flashing. Or sometimes, the stop will just flash once and then nothing will happen. I've invested a lot of time into this. My OS is up to date. I have the most recent version of Pro Tools, R16 driver, and firmware. The only thing I can think of that could be causing the problem is my CPU. The driver page for the R16 "recommends" Intel chipset, but I have an AMD processor. However, I've been told by at least 3 very intelligent individuals that shouldn't really matter. Playback/record function fine when I use my Mbox Mini in place of the R16, but then I might as well just go back to using my XP machine if that's all I can do. The frustrating thing is that the R16 does work on my friend's computer. And the only difference I'm aware of between his and mine that could possibly matter are that he has an Intel CPU. But again, that shouldn't matter! This is driving me insane. I've been all over the internet looking for a solution. I/O settings are fine. I deleted prefs. The interface works as a sound card with Windows, but not with Pro Tools. What to do??
Re: PT10 Not Playing/Recording
How About software designers? degrees? working in the industry? I'm trying to be a jerk here but I'm just trying to get you to understand the relevance of your statement.
So is what I would do is I would start a ProTools session without the zoom connected (aiso 4 all)
make sure you don't have any problems there record some audio mix plugs and see how it goes You do have aiso 4 all installed don't you ?
Since you didn't tell us much of anything about the host computer:
http://duc.avid.com/showthread.php?t=300050 |
I do. That's what got me to where I am now. I can record, but playback is choppy. All functions work fine with a different interface.
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Curious^^ I took the report to show 3 or 4 hard drives. If indeed you have a single drive that is partitioned, that is the very first thing to address. WD Caviar Black drives are an excellent choice for recording. The next thing to consider is; maybe pull the nVidia graphics card and try a modest ATI card(ATI tends to work better with AMD systems, while nVidia cards tend to work better on intel). Granted, this would be an experiment, but it would would only be a $30-50 one. If all else fails, its possible that this is one of the AMD cpu's that just doesn't like Pro Tools. In that case, I would check out Reaper, Cubase or Sonar.
May I ask why you suggested a partitioned drive is the possible cause for the play pause stop issue? thanks.
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
reason rewire midi not playing first note in pt10 | mistalo | macOS | 20 | 09-05-2016 02:25 PM |
Pan Automation not playing correctly in PT10 | WernerF | macOS | 31 | 03-27-2015 10:55 PM |
playing PT10 sessions on earlier versions | fork-media | Pro Tools 10 | 6 | 06-26-2013 08:13 AM |
Loops playing double speed in PT10 HD | belolab | Pro Tools 10 | 0 | 03-20-2012 09:13 PM |
Is VEPro Playing Well With PT10? | Carl Lie | Pro Tools 10 | 6 | 10-22-2011 04:52 PM |
