error message -9073
hi,
the message says: 'DEA can't get audio from drives fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load.' i assume i will have to try de-fragmenting. outside doing this is there anything else i should try? |
Re: error message -9073
Are you recording to your system drive? That is not recommended. Try recording to a physically seperate drive. Do not use a USB drive.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
what kind of storage capacity etc. is usually recommended for an external hard drive dedicated for use with pro tools?
That depends on the amount of recording you plan to keep on that drive. I can get by with a 60 gig drive but I backup and remove files regularly. If you don't want to do all that maintenance (you should still back up by the way) you might consider a 250 - 500 GB drive. They're really affordable nowadays. Again, Firewire is recommended and USB is NOT recommended.
Obsidian Dragon
thanx a lot. i picked up a seagate 320gig firewire drive. hopefully after it's installed and running this problem will clear up.
You can try on Preferences/operation preferences/open ended record allocation and set it to about 10 minutes or less.
You can try to partition your drives so they are not too big. Believe me, even though were talking milliseconds, the large drives are sometimes problematic for audio files.
Camilo Toledo |
(-9073) error message | Jtapp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 09-15-2010 02:30 AM |
error message (-9073) | donpato | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-23-2008 05:27 PM |
DAE error message -9073 | T_Connections | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2007 10:21 AM |
Keep getting error message (-9073) | Mistermac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-01-2005 08:54 AM |
Help Please! (error message) (-9073) | Mistermac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-03-2005 03:17 PM |
