S3 and Sigma - Any users?
I'm trying to figure out what direction I want to go with my next Mixer. The SSL Matrix has looked very tempting to me, but if it works well, it seems that an S3 with an SSL Sigma would be more ideal so that you would get the tight integration of the S3 with the SSL sound, control and monitoring from Sigma.
Is anybody running this set-up? If so, how is it working for you? My area I keep getting stuck is that I use a Hearback system which requires that I am able to split the outputs to the Hearback system (Pre Fader), but with talkback somehow integrated. Anyways, I'm curious how it works for people who may have a similar set-up.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Re: S3 and Sigma - Any users?
It depends on your workflow. If you do most of your mixing in PT then be aware that the SSL only has very basic HUI control and when compared to the S3 with the Dock is nowhere near as functional. If you are going to want to do a lot of mixing outside of PT then obviously the SSL might be the way to go.
I agree with Eddie, EuCon is amazing. My favorite feature is the plugin control. The ability to load a plugin and turn a knob on the surface is phenomenal. No plugin mapping is required. I imagine a lot of work has been done by the product designers on the front end because most controllers these days require some sort of plugin mapping. Honestly speaking, purchasing a EuCon Control surface has been the only purchase I haven’t had buyer’s remorse. My only wish is that I had an S3 or maybe even an S6!
Have you done extensive, properly controlled A/B testing using super clean summing like the SSL? I have. I've done extensive tests with a Duality and my conclusion was that summing with clean tools like this is a waste of time and money.
If you do it with something that has transformers and will offer some coloration, it can be a nice subtle addition. |
I’m an early Sigma user and use it together with 2 Avid artists via Sigma Delta (mackiecontrol) and EUCON in Cubase 9
Besides great sound and fabulous workflow, What exactly would you like to know? |
Drew,
Yes, I listened to their files on the site with different summing. When I turned off the labeling and scrambled them up, I couldn't easily tell any difference. I'm needing some way to bring together multiple outputs from Pro Tools together outboard. I use a Hearback system so that everyone has their own control of their mixes. So while tracking, I have different instruments routed to different outputs and I need some sort of mixing device for me that can bring those signals together for me in the control room. I also need to add talkback for the Hearback system and have monitor volume control. Summing for me would be more of a luxury for me and I probably wouldn't use it a ton. Although, I would see if I start hearing a larger difference as time went on. I definitely would want the S3 for DAW control. It just seems like the S3/Sigma in theory would be close like a SSL Matrix, but with an S3 for DAW control.
For example, I see that you need to set up your 16 channels to the left of your project to control Sigma. What happens if you hide those tracks? Does it mess up Sigma?
The 16ch was the old way of working, now u use the sigma delta plugin, which you can control via eucon (pan, fader, mute, mono toggle, solo, out a/b)
I think it works great that way. |
I’m not exactly sure why you would need to do that but, why don’t you just use another Hearback unit?
I'm also considering using an SSL X-Desk as a small format mixer to go along with the S3. I like that there would always be hardware faders to reach up and grab for the mix in the control room.
MCU Mode & SSL SIGMA v2.00 | Raphie | Artist Series | 0 | 04-08-2016 12:20 AM |
Pro Tools + SSL Sigma Automation Not Working | Oroz | Pro Tools 11 | 4 | 09-14-2015 09:29 AM |
SSL Sigma ... Opinions | Becharax | General Discussion | 16 | 04-02-2014 02:33 PM |
vst2retas users inhere? non-users, read this to ! | ikke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-09-2004 03:41 PM |
Need users opinion: New digi users domain name (unofficial).. | David Fisher | General Discussion | 2 | 07-30-2002 09:27 PM |
