Old 06-12-2018, 09:40 AM
nigel smith nigel smith is offline
Default Digital audio de-embedding
Does de-embedding digital audio from an HDMI or SDI source cause any shift in audio quality or latency? Or is it a direct and simple conversion?
I'm thinking of using one for Pro Tools 48Khz 24bit 5.1 and 7.1 output but don't want to degrade signal path.
The signal will be passed to a CP750 cinema processing unit.
Thanks in advance for any advice.
Pro Tools HD Native 10.3.7 on Nehalem 2.8 Quad core with 16Gb RAM.
Old 06-13-2018, 01:58 AM
papalou papalou is offline
Default Re: Digital audio de-embedding
AFAIK, HDMI embedded audio is PCM, so there's no problem with quality, but I'm not sure that you can easily output ProTools audio using HDMI (could depend on your hardware). And depending on your de-embedder, you'll have to deal with some delay than can exceed 1 frame.
You should have a look on ATV de-embedders, best gears I've found so far with a low price point (and small delay, of course). But still interested if someone has other tools for this job.
Old 06-13-2018, 04:46 AM
fresler fresler is offline
One of my legacy system is running a PT9HD via Hdmi to a 5.1 Yamaha AV receiver.
It's just my "at home" machine, so no need to stretch my budget.
Conversion and monitoring quality is not really something worth talking about, but the benefit of running just one Hdmi cable from a Mac to the receiver, no audio interface involved, is priceless.
HTML code is On
SDI audio embedding? rprovideo Post - Surround - Video 8 08-15-2017 07:35 AM
Embedding Rig Settings Help Frettin Freddy Eleven Rack 13 11-12-2014 12:32 PM
PT embedding awful, awful noises into my audio. Houston, we have a problem.... emorganproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-26-2010 02:41 AM
embedding timecode into a .bwf?? Murmur Music Post - Surround - Video 1 03-06-2008 12:38 AM
Embedding Audio into SDI V10 David.Klooker Post - Surround - Video 0 03-22-2006 08:33 AM
