Structure won't play the whole sample.
Been having this problem for a long time, probably ever since I bought Structure when it came out… Problem is that occasionally Structure stops playing the whole sample, the sound is cut off after around 1 second. Only solution is to restart Pro Tools, then it starts to work again. Yesterday I upgraded from 1.05 to 1.1 but the bug is still there. Anyone else that experienced the same problem? Thanks Niklas PT 7.3 - D002R WIN XP SP3 Intel Core i7 2.67 GHz 3 GB RAM |
Re: Structure won't play the whole sample.
Niklas, Structure 1.1.0 systems requirements state Pro Tools 8 or higher. Sample cutting off was a bug with Structure 1.0.x but has been fixed with Structure 1.1.0. But you're running Pro Tools LE 7.3 and this could be contributing to the issue.
Aaron Mulqueen - 001 HD Native |
Thank you very much for the answer!
Probably time to do that Pro Tools upgrade soon... :) |
Did i just overlook it.??????? Thanks,
Look here -->> http://shop.avid.com/store/product.d...88865113852624
However, 20GB worth of samples for 50 buck doesn't seem like a bad idea.
Structure 1.1/Structure Free Sounds/Sample folder | DTheone | Virtual Instruments | 9 | 03-29-2011 06:25 PM |
Structure won't play full sample | Pegasussongs | Virtual Instruments | 4 | 07-03-2010 04:03 AM |
Structure LE won't play rx2 files | teejmusic | Virtual Instruments | 7 | 10-14-2009 05:44 PM |
Structure vs. Play (Eastwest) vs. PT8 | jmbakula | Virtual Instruments | 2 | 08-03-2009 08:04 PM |
Structure Question: setting up sample to play till end | aliaspail | Virtual Instruments | 21 | 03-23-2009 04:24 PM |
