Did any component combination ever work properly with PT10 or Logic X?
I realize its the combination of eucon version, DAW version, XML file and OSX version that come to play for this S3 thing to work properly.
Id like to know if anyone ever witnessed Pro Tools 10 and/or Logic X fully working with S3? I get most of it to work but its always the left and right hand switches+clear Solo and a few more switches on the sides that do not work. Both in PT10 and in Logic X. So i am wondering if there is any combination of the above elements that actually makes all these switches and features operational on PT 10 and on Logic X. I dont mind giving up soft keys per Eucon 3.2.2 if it means using an earlier Eucontrol. I also dont need it to be "officially" supported by Avid. Just wanna work... As far as Logic, i don't get it, The mere fact that it has Application switcher on board, and Kyle officially generated an XML for Logic means it supposed to work... so what's up with that..? Can anyone share his experience and say if there is any combination of components that actually makes S3 fully operational with the DAWs i am using (PT10/Logic X)? Thanks! |
Re: Did any component combination ever work properly with PT10 or Logic X?
Not a Pro x user but I have it so could check if you want
PT 10 is unsupported with the S3 and never has been.
I don't suffer from insanity -- I enjoy every minute of it ! Avid S3 Artist Transport Pro Tools HD 12 UAD Apollo 8P Audient ASP 880 Mac Pro TrashCan 3.5 GHz 6-Core Intel Xeon E5, 32GB ram Adams A77x UAD Quad Thunderbolt Satellite |
Thanks!
Regardless of being officially supported or not, PT10 does work with the S3, however, the function keys on both sides do not work as are the clear solos and such. Logic X same story. All working excepet for the function keyss on the surfaces left and right sides. So: A. Logic is supposed to be supported yet same exact behavior as PT10 which is not supported but IS working the an extent. B. What im trying to figure out how to isolate what is supposed to work and what not so i can eliminate user/ installation errors from things that do not work-period. I dont seem to be able to get clear info. |
What's the issue with using 11 or 12 as they work fine ? Is there somthing else keeping you tied to version 10 ? Just to confirm you are now in Eucon 3.2.2 and double checked the firmware ? If I get a chance tomorrow I will have a look and see what's what with the S3 and logic but I've never had a need.
Main reason for PT10 is that i share big projects with other participants around the world and most of them never wanted to upgrade to 11. So were all conformed to 10.
Second reason, and even more important, is that i like working in Logic more then PT since producing is way better for me in Logic. Often i am already with good sounds and half way mixed really, so do not want to port the project to PT and start mixing from scratch over there. |
Plug ins will not display properly in PT10 | Deano | macOS | 1 | 05-18-2012 02:30 PM |
Bounce not working properly in PT10 | b mcgibney | macOS | 2 | 01-13-2012 07:39 AM |
Best Mic/Pre Combination for Mean Tone anyone??? | Zap Launcher | General Discussion | 14 | 11-13-2008 12:17 PM |
Can I use this hardware combination? | mozart | Pro Tools TDM Systems (Mac) | 2 | 09-09-2008 08:10 AM |
Help for Microphone combination | dave_koz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-25-2002 06:37 PM |
